Question about Craftsman 25cc Gas Line Trimmer
Head on my craftsman weedwacker no longer spins.
Is the shaft or cable it's connected broken?
  • 64 Answers
It sounds like the inner cable has broken.
Posted on May 04, 2010
Barely used weed wacker head stopped turning clutch seams loose has play can i unscrew the clutch?allen wrench??
If your clutch is spinning you more than likely have broken the drive shaft that goes down to the head. it is fairly common with craftsman weed trimmers.
Nov 06, 2015 | Garden
While trimming a type of brush wrapped around the cutting head and made the unit stall, upon clearing it the head now is weak and does not spin with enough power to cut; how can i fix this?
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below
Craftsman 17 25cc Weedwacker
Sep 15, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Why does the head stop moving?
with trimmers , there is a shaft or as in a bent shaft a cable that has square drives and ends
these can become oval or break off if continual heavy loads are applied to the cutter head
next there is a centrifugal clutch at the top of the shaft and if continually used in heavy work that clutch will wear out and not grip sufficiently to drive the shaft
most cutter heads do not suffer problems other than to get loose and work down the tube thereby allowing the square drives to part
Jun 24, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
Does trimmer head spin at idle
this is a hard question ,ill start with the text book answer , NO the idle should be low enough to disengage the clutch and remove power from head . but in reality this always is not possible , me I judge a clutch and engine idle % to be working correct if I can put cutting head on ground and not have it take off with throttle closed off
May 26, 2015 | Craftsman WeedWacker Gas Trimmer 25cc...
Not sure what you mean but if you are saying the weedwacker head is not engaging it may be the cable that goes from the motor to the weedwacker head and runs down the inside of the shaft.
May 24, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Why does my weedeater over heat?
Clogged cylinder fins?
Too lean a mixture?
Define overheating.170-250* is OK.
Possible binding drive head or cable.(Working too hard).
May 16, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
Cutter spins freely
The driveshaft is broke in the tube or the head drive is broken or srtipped out. Take head off and pull out the cable. It just slides out.
Apr 16, 2014 | Craftsman 25cc Gas Line Trimmer
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
How do I thread my Craftsman weedwacker?
How do I Re Tread my Craftsman 13"
4.0 amp electric weedwacker line trimmer?
May 29, 2010 | Craftsman 27cc 2Cycle Full Crank Curved...
Craftsman 25cc Gas Line Trimmer Logo
349 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
