Question about Traxxas T Maxx 3.3 Monster Truck
When i start my tmaxx it tries to take off by itself wide open i cant stop it just keeps going
    Problem Solver:
  • 15 Answers
First try turning the throttle trim on the controller back to zero. Or less.
Posted on Oct 08, 2011
  • 748 Answers
Hi
Assuming the transmitter is still set correctly then the problem is either your receiver is defective or your throttle servo is defective and/or both. Don't start the engine but switch the servo wires. If the switched servo now doesn't work then your receiver is bad, if it does work then the other servo is bad. Good luck
Posted on May 05, 2010
I cant seem to start a new session it keeps quiting before booting
When you say a session is it opening to the login page and terminating and shutting down?or where is it stopping? Have you tried opening on safe mode? If it opens on safe mode go to control panel under users and add a user with admin rights after that log off and login with the new account and you can transfer any personal data from one profile to the new one. Once done go under control panel and delete the entire bad profile. Once completed restart. If its on windows boot, you might need a windows disk to fix.
Mar 19, 2013 | Digidesign Mbox 2 Barebone
Tmaxx 3.3 starts and runs when holding off the ground but as soon as i put it on the ground it dies
Change your clutch shoes and spring, if shoes are still good,then just the spring
Mar 07, 2013 | Traxxas T Maxx 3.3 Monster Truck
Engin stops sometimes when I slow down, usely starts back up and run fine. Now I am at home it starts then stops, now it turns over but will not start and run.
it has a dirty throttle body. get some carb cleaner and a tooth brush.remove air cleaner hose at the throttle body. block open throttle to wide open {engine off of course} or have someone hold it to the floor.spray cleaner into body and scub with tooth brush especially were the throttle plat touches the bore when at idle and the throttle plate itself.spray brush,spray,brush. put hose back on and start engine. you might have to give it some gas to atart it then its going to run rough for a few seconds but it will clear up.slowly lower foot from gas pedal and allow to idle.put in reverse let run in reverse for a few seconda do the same with drive.it has now began to learn what position the stepper motor should be in when throttle is not depressed.it may stumble a couple of times at sops but will soon correct itself
Mar 20, 2010 | 2002 Chrysler Town & Country
Hi there - is this a live online help service?
The battery in the EZ Start wand might be going bad or needs completely discharged. Nicd and Nimh batteries will develop a memory if you just keep charging them over and over again. This will cause them not to take a full charge and not operate correctly. Some aftermarket chargers have dischargers built in or you can make one by soldering a couple of 1157 automotive tailight bulbs together with some wire and a connector that fits your pack. Plug battery into tailight discharger and let it go until the lights start getting dim. If you let it go too long you can damage the cells in the battery pack.
Nov 15, 2009 | Traxxas T-maxx 4wd Nitro Monster Truck
When starting car engine will rev wide open.
check the throttle return spring, possibly broken or has come off
Jul 23, 2009 | 2001 Lincoln LS
My Water Keeps Draing
The seal for the drain is leaking. It is either the drain itself or the seal beneath the drain. If it is the seal beneath the drain then you will have water going underneath the whirlpool and causing damage; if it is the drain itself simply replace the drain as it's seal is either broken or worn.
Jul 22, 2009 | Home
Dvd/cd drive door keeps opening and closing by itself
If the trouble isn't being caused by some screwy virus or software problem, the best solution is to replace the drive. New drives are quite inexpensive and widely available in retail stores (at higher prices) and online.
May 27, 2009 | HP (D4384-63002) (d438463002) Internal 32x...
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
Oct 16, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Traxxas T Maxx 3.3 Monster Truck Logo
329 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
