Question about Konica Minolta bizhub 350 All-In-One Laser Printer
I WANT TO BE ABLE TO PRINT FROM MY COMPUTER TO MY PRINTER
  • 3 more comments
  • msjboutique May 03, 2010
    I need to know how to install my dell computer
    to my bizhub c350 my ipc # 192.168.2.155
    I need to no how to install my bizhub c350 to a computer ipc 192.168.2.155 the drive c350 is not listed what other one is compatiable
    President:
  • 3,278 Answers
Hello.
Install your Bizhub as a TCP/IP printer:
Select Add Printer
Select Local Printer (unselect attached)
Select "Create a new port"
Choose Standard TCP/IP
Enter the TCP/IP Address as 192.168.2.155
Install the Bizhub's driver (should be in CD that came with the printer).
Hope this helps.
Posted on May 03, 2010
    Guru:
  • 1,049 Answers
  1. Either set a static IP for the printer or attach your computer directly using USB.
  2. Setup the printer on your computer using the driver for the printer. If the printer has Postscript capabilities the PS driver is better than the PCL driver.
  3. If the printer is USB setup like any other printer, if the printer is IP then specify a local port in the Wizard and type the IP.
  4. Choose the driver and install
  5. Afterwards go under properties and select the printer components such as duplexer, extra trays, etc.
  • 3 more comments
  • NA NA
    NA NA May 03, 2010
    Add Printer Wizard
    1. Log in as Administrator
    2. Click Start > Printers and Faxes > Add a Printer
    3. Click NEXT
    4. Choose Local Printer Attached to this Computer
    5. If attaching USB, detect printer, otherwise if using an IP do not check “Automatically detect and install my Printer”
    6. If not using USB, choose, “Create a New Port”. The type of port is “Standard TCP/IP Port”
    7. A new wizard will open if you setup for IP.
    Add Standard TCP/IP Printer Port Wizard
    1. Click Next
    2. Under Printer Name or IP Address enter the IP
    3. The port name will automatically become IP_[IP address], you want to leave this.
    4. Hit Next
    5. Chose Generic Network Card.
    6. Click FINISH
    Add Printer Wizard (Continued)
    1. Choose a driver, most likely need to click “Have disk”
    2. Browse for the INF in the driver folder click next
    3. choose printer name
    4. Allow files to copy.
    5. Click FINISH
  • NA NA
    NA NA May 03, 2010
    Customizing Settings (Do this or some options may not display when you print)
    1. Right click the printer
    2. Select properties
    3. click on “Device option Settings”
    4. Add components until the picture matches your unit.
    The names are ambiguous, so here is a list of translations.
    a.Tray 3 and Tray 4 are optional trays
    b.LCC - Large Capacity Cabinet
    c.AD-16 – Duplex and Switchback Unit
    d.HDD-6 – Hard disk drive kit
    e.JS-203 – Job Separator Tray
    f.FN-117 – Finisher Tray
  • NA NA
    NA NA May 03, 2010
    You may need to update the driver, but it'll work. Try this site to get the Vista/Win7 drivers.
    (If you absolutely can't get it to work, the HP Laserjet 4 PS driver works for almost any Postscript printer. But try the driver above.)
  • NA NA
    NA NA May 03, 2010
    Did this help you?
  • NA NA
    NA NA Jun 04, 2010
    Here is a link to the DRIVER
    this along with the instructions I provided earlier should allow you to print.Please remember you can re-evaluate the user score if this link proves more helpful then previous posts.
    Thanks.
I am not able to print properly
  • be sure that the the computer and the printer connected.
  • turn on the printer
  • install the printer driver on the computer
  • when you want to print select the printer from your computer
  • order the computer 'print'
  • you will get what you want
Apr 01, 2015 | HP Deskjet 1510 All-In-One Printer
Printer will not print
If you are talking about a printer that is hooked up to a computer make sure the printer is selected by the computer to print. Go to the control panel and to printers and enable this printer. It may read "make this my default printer.
Mar 26, 2014 | Panasonic KX-FLB801 All-In-One Laser...
Not able to print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 25, 2012 | Lexmark X8350 Print, Scan, Copy and Fax...
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
Mar 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Lost connectivity after power outage
If this is a printer WITHOUT WiFi or bluetooth - and you have it connected to another computer (Print Server) via a USB cable - you need to make sure you can see that computer from the other computer you are printing from. Use the network explorer - if you can see the computer and the printer you should be able to print to it.
Sometimes, it may be secured with a password. I found if I can map a shared drive from my laptop to my print server then I can print again. So see if you can see the printer and printer server computer from the other computer. If so you may need to add that printer again to you printer list.
May 01, 2017 | Zonet ZPS3611 Print Server
Printer is on but will not print. Brother HL-2140 laser printer. The print log status reads = Error - Sent to printer.
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
  1. Clear the printer queue
  2. Shut down the computer
  3. Unplug the USB cable from your computer and your printer
  4. Unplug the power cable from the printer and wait 15 seconds
  5. Plug the USB cable back into the printer and the computer.
  6. Plug the printer’s power cable back in.
  7. Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thanks,
Pat
Mar 29, 2010 | Brother HL 2140 Laser Printer
Can,t print document from computer to a brother 3420c mfc, computer says it is online and ready and the default printer, when i saf print and the prother dialog window comes up i say print and the document...
Hi, Billy.
1. Remove your printer from Printers and Faxes
2. Disconnect the printer cable.
3. Restart your computer
4. Reconnect the printer cable.
5. Your computer should see the printer and install the driver.
Hope this helps.
Sep 26, 2009 | Brother DCP-7030 Digital All-in-One Laser...
Switching from copy to print from computer
If you look carefully at the printer you'll note that there is no button for "Print" and the reason for this is that all the other functions are for using the printer as if it wasn't connected, nor needed a computer.
All your printing functions that DO use a computer require you to interact with the printer via the computer.
In short, to use the printer from the computer you'll need to make sure you've installed the correct drivers (see your installation CD or the Canon website) and then plug the printer in using a USB cable connection to your computer. If the computer recognises the printer you'll then be able to print.
In a nutshell if your printer is connected and drivers installed properly it doesn't matter what your printer has selected on the printers own control panel, you just print :)
Hope that helps.
Feb 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Docments
Every printer has a unique print driver on computer, and each and every printer uses a different one, so there goes it cant be my computer. The way to tell if it is a printer or computer problem on your machine is to Turn off, unplug from computer, ensure your printer has paper, power it on, wait for ready/online lamp, then press the "go" button 5 times super FAST. Status page should print if it does, then your problem is in fact the computer or the print driver not installed correctly on your computer, as I suspect may be the case.
Post back once you have verified if you have a printer or a computer problem.
Jan 08, 2008 | Brother HL-2040 Laser Printer
Cannot print unless I turn off computer and then reboot.
I'm not a big fan of Lexmark in general in part due to their software and drivers. For me this type of behavior from their printers/software became common about a year ago, the fix being to use the more generic Windows supplied printer drivers. I would suggest that you uninstall all software the printer installed and remove all of the printers print queue(s)including any associated with the fax function. Unplug the printer USB cable from the computer, reboot your PC and reinstall the printer from scratch using your original installatin CD.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
394 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
