Question about Dishwashers
I am trying to fix my Hoover hfi3015 to the cabinets as it tips forward when opened I cannot find any instructions on homw to this? any ideas?
    Guru:
  • 351 Answers
Hi , there should be two small brackets at the top edge of the machine. you need to have the door open to see them. Mount the washer using screws thru these brackets into the bottom of the counter top.
Posted on May 04, 2010
Hoover 201M 5.00Kg Heavy DutyTop load leaks slightly . I cant see any easy way of removing the outer case to look inside to find out where the leak may be. there are only a few screws holding the...
  • Unplug the washing machine from the wall outlet.
  • 2
    Remove the plastic end caps on the left and right sides of the control panel using your fingers, and then remove the screws under the end caps.
  • 3
    Lift the control panel up and rotate it 180 degrees.
  • 4
    Unplug the wire connector from the top of the cabinet and then use a flat-head screwdriver to release the spring clips on the left and right sides of the cabinet.
  • 5
    Tilt the cabinet toward you, then lift and remove. Set the cabinet aside.
  • New top load machines all have the cabinet where it comes off forward and the screws only hold the control panel on.
    Apr 04, 2011 | Washing Machines
    My belt has broken on my hoover vhc 392t and im not sure how to replace it
    you will need to open the dryer up:
    http://www.partselect.com/dryer+open-cabinet+repair.htm
    and make sure the belt is routed correctly:
    http://www.applianceaid.com/images/belt-config.JPG
    Jan 11, 2011 | Hoover Dryers
    Hoover washer/dryer VHW854D SHOWS ERROR CODE E11. Machine switched off and door opened. Wash cycle had not started. Door closed and machine switched on and all works OK. Any ideas?
    I have exactly the same problem. Hoover Service Centre told me to tip a bucket of warm water into the drum and leave for 5 minutes before switching it back on. The idea is that the machine may be affected by the cold weather. Needless to say it made no difference and Error 11 remains - I am expecting an engineer on Thursday 23 I'll keep you posted on the outcome.
    Dec 20, 2010 | Washing Machines
    Washing machine water inlet valve needs repacement. Have pary But do not know how remove washer top to get to the valve assembly. Appears not to open by poping spring loaded fasner.
    Try this;
    1) Unplug the washer. turn off the water. remove the fill hoses.
    2) remove the 2 Phillips screws in the front on either side that retain the console. On some machines, these are hidden under console end caps that must be pried off. On newer models, they’re on the back of the console and you only need to back them out about halfway. On most of the latest models there are no screws, rather there are two clips that you release by inserting a putty knife under the console from the front. apply slight force forward on clips and they'll release as you pull up on consoile lightly.
    3) lift the console forward to unhook it from the cabinet top, then up and away from you. it will hang back out of the way if the washer’s away from the wall far enough. unplug the lid switch plug, it'll be the one with 3 wires, usually white, brown and green. then use a large screwdriver to pry up the 2 large clips that hold the cabinet to the washer back panel.
    open the tub lid, grab the cabinet and gently pull forward and it’ll unhook from the retainers on the base. Lift the cabinet off and set it aside, you'll need lot's of room, but it is easy to work on.
    4) if you now look to the right of the tub at the back wall while facing the unit you'll have access to the valve.
    *NOTE, To put the cabinet back on, open the cabinet lid again, now looking down through the lid opening, hook the cabinet front under the washer frame while keeping the cabinet tilted slightly towards you.
    Rest your foot at the cabinet base to hold it in place, as you tip it back down onto the base. make sure the 2 notches at the back on the bottom(frame) line up with the notched holes in the cabinet bottom.
    Snap the 2 big cabinet clips back into place, If one side’s gapped, it means one of the notched holes is mis aligned. remove the clip on that side, tilt toward you slightly, and push the side down into place. Then re-install the clip.
    plug the lid switch in, re-attach the console. and Bob's your uncle.
    you should be back in business.
    hope that helps,
    good luck
    Sep 26, 2009 | Kenmore Washing Machines
    My Maytag mtw5740tq0 is leaking from the bottom front after running a heavier load. What is the reason, and is this something that I can fix myself?
    check your gasket ... gray rubber around the door ... if there is a tear or hole.. it will need to be replaced
    Sep 21, 2009 | Washing Machines
    How do you change the switch that is located under the lid? model lsl9244ezo. switch part number 3949237
    I fixed mine by extending the tip of the rod that pushes the switch down. If you want to replace it you need to undo the two screws on the control head at each end facing front. Pull control panel forward and flip up. Un plug wires going to door switch. Un snap the two gold bracket retainers that hold back and cabinet together. Lift cabinet from rear and tilt forward to get it out and access switch.
    May 18, 2009 | Washing Machines
    Install the switch
    Anthony, you usually need to pull the 3-sided cabinet off the machine to get that part installed. Some can do it from the top, but having the cabinet off is the easiest. You have to open the control panel up first, then unhook the lid switch connector harness, then pop out the two straps that secure the cabinet to the back/bulkhead. Now the while cabinet/top of the washer lifts away by tipping it up and forward towards you. Now you will see that lid switch bracket assembly you want to replace is easy to get at.
    Dec 13, 2008 | Kenmore 15944 Top Load Washer
    Brush won't rotate when pushed forward
    I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
    Dec 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
    Dishwashers Logo
    197 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
