Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Suction hose collapses
  • 78 Answers
This is a pretty common problem for the Dyson DC07. The cause 99% of the time is that there will be a blockage in your hose that causes the hose to contract. I have made a video that shows how to remove the hose to check it out. If you end up needing a new hose I would check out nelson vacuums or vacuumspot.
If this is a helpful post for you please take a moment to leave a comment or a testimonial I love to hear back from people.
Happy Vacuuming :)
Posted on Dec 09, 2010
Hose collapses
If you're sure the hose and any attachments is clear of debris, you should contact the manufacturer.
Jul 28, 2015 | Vacuums
How can i unblock my cleaner ?
There may be blockage in the hose or the hose may have collapsed internally.
Oct 23, 2014 | Vax C90-M1-C Mach 1 Complete Multicyclonic...
I put a new bag in my electrolux 2100 and it seems like it has half of the suction. What seems to be the problem. Does it need a new upper motor gasket?
Take the hose off, turn the vacuum on and see if there is good suction at the vacuum where you attach the hose. If there is good suction at the vacuum there is either a clog in the hose or if it is an old hose the liner inside the hose may be collapsing when you turn the vacuum on. If that is the case you will need to purchase a new hose. I have hoses for sale on my website and on ebay.
Mar 06, 2014 | Vacuums
Vax c90 p 2 b 200wI have cleaned filters but hoover/suction keeps cutting in and out?Can you help ?
check for a partial blockage in the wand/ hose ( rag-ball--hair ball ) Check that the hose is not collapsing at past kinks.
Jun 11, 2013 | Vacuums
I have cleaned out the vac and changed the filter but I can hardly **** up leave on the garage floo.
Try this:
Detach hose, turn on vacuum, hold hand in front of intake to check airflow/suction. If it seems good, you either have a clog in the hose, are bad leakage.
If it's a clog, try placing end of hose in the exhaust port, turn on machine, and blow clog free. You may need to place other end into intake. This should clear it.
If hose is cracked, punctured, or smashed/collapsed, replacement will be necessary.
If there's not much suction at the intake, it may be time to replace your vacuum, or at least the motor.
Nov 13, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
How do you remove the hose to ck for blockage?
If the hose collapses and there is no suction, that is a sure sign of a clog. The clog will be on the opposite side of the collapsing hose from the motor. Good luck.
Mar 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
Hi its Darran at Dyson.
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Coils in hose attachment collapsed at top causing hose to collapse and not suction, how do I fix this?
To fix it properly you need to replace the hose. If you are low on cash try going to a thrift store and get a used one. If you put something in the hose to prevent the collapsing it will quickly clog the hose.
Jun 20, 2009 | Bissell Upright Vacuum - The Pet Hair...
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hose Collapses When I Try to Use Wand
Hi Both.
Ok you have A blockage, Remove flexi hose completly from rear of machine & completly remove wand & handle from the hose.
Now check flexi hose for obstruction if none present move on to the wand & hanndle look down through tha wand for any obstruction look very carefully where the plastic handle meets alloy tube there is A slight bend here often A coin gets stuck here & flips accross to block oppening when you try to use wand.
If you cant see anything coin etc put hose back on machine & switch on there should be good suction from the flexi hose,
Now with machine still switched on push alloy pipe back on if the hose suddenly pulls back & there is poor or no suction you definately have A coin stuck at the bend.
You will need A broom handle or other long solid pole to hit it out.
http://dysonmanuals.llc.nu/
Aug 03, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
62 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
