Question about 2wire (1000-400108-001) Router
Use 2 wire to run laptop
I have a 2 wire hookup and run 2 pc computers on this. I want to buy a laptop. My question is can i run the laptop on this 2 wire hookup?
  • 68 Answers
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities Use 2 wire to run laptop - dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
Posted on May 03, 2010
Will not power on at all need to get data from hard drive .i hooked it to adapter can feel it running but will not show up on my computer old system was xp media new one is 7
Remove the drive from your old laptop. Order a Sata to Sata/Ide hard drive adapter or a Sata wire with a usb connector from a place like Tiger Direct or Staples. Plug in the Sata wire into your drive (It is the only wire you need to make the hookup complete) then check to stt if Windows 7 recognizes the drive. If not you will need to get some software (downloadable and usually free) that will transfer files between operating systems.
Dec 31, 2012 | Toshiba Satellite A105-S4284 Notebook
Internet hookup wiring needed
That a bit vague. Your ISP should supply everything but a Ethernet cable to plug into computer.
Dec 20, 2012 | Toshiba Libretto 110CT Notebook
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
What driver do i need for a samsung wave s8500 to be able to conect my phone to my laptop and upload photos and thing thanks
You should be able to go to your phone retail store and purchase an adapter to connect your phone to your computer via usb. Some phones come with these adapters at the time of purchase so double check before you go and buy one. It will hook directly into your phone and the other end will be a usb hookup. Its allows your phone to act as somewhat of a flash drive, transferring files back and forth from your phone to your computer and vice versa.
Oct 08, 2010 | Computers & Internet
What wires / connections do i need to run my home pc through the t.v
Depends on what hookups the Tv and PC have. Newer laptops have a HDMI jack, otherwise the external monitor jack will do. Then the TV must have a monitor hookup. Most likely not. So then you'll need some type of a conversion cable to go from PC to TV. Check your local Best Buy for the cable.
Nov 25, 2009 | JVC LT32DS6 32 in. HDTV-Ready LCD TV
How do I hookup my new laptop to my existing isp
If you have connected your net to desktop with wire then simply remove wire from desktop and attache it with laptop......if you have wireless router then there is no need to replace wire.....just turn the wireless on in laptop....both will work simultaneously...
Oct 01, 2009 | Computers & Internet
Wireless internet hookup
Any wireless pc card will work.
Jan 20, 2009 | Panasonic Toughbook 47 Notebook
Wiring problem
waste of time.
if you need a monitor, buy a monitor.
if you need a tv, buy a tv.
Sep 27, 2008 | LG Studioworks 700S 17" CRT Monitor
Laptop
It's the Sony version of firewire. (a type of connection similar to USB, but designed differently) Most computers come with some kind of firewire hookup, but ever since USB2 came out, it's mostly there for backwards compatibility just in case you have a firewire gadget of some kind. There isn't a whole lot of hardware out there that uses it anymore. It came out about the same time as USB1 and was a lot faster, but far more expensive than USB2, so it's kind of pointless.
Jul 28, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Ethernet Adapter for IBM Thinkpad
Try this link
This is for a wired card(Cat 5e ethernet cable from card to modem)
May 13, 2008 | IBM ThinkPad 760 EL Notebook
2wire (1000-400108-001) Router Logo
267 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Bruce Silvernagle
Bruce Silvernagle
Level 1 Expert
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
