Question about Hotpoint HSS25GFP Side by Side Refrigerator
My ice machine works fine but I'm not getting any water to the outside button to receive water.
    Guru:
  • 351 Answers
Hi .. ypur problem is likely that the tube running to the water dispenser is frozen .. you should defrost the unit and free the water tube of any ice or obstruction.
Posted on May 03, 2010
Whirpool ice machine not getting water
If your certain the line isn't frozen. Then your valve is bad
Apr 20, 2015 | Whirlpool Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I just received a Sunpentown model IM 100 from a friend with no instruction manual. I?m not sure where to put in the water in the ice maker. Also there is a plastic male threaded drain on the left side of...
The outside male thread drain should have a cap to hold the water; this is the drain for draining the unit. Filling the unit is as you described, simply lift the lid and add water into the tub. It should not be leaking water from under the unit ... that could be a problem. Good luck!
Dec 05, 2010 | Sunpentown SPT IM-100 Portable Ice Maker,...
The outside door water does not work
Can I assume the ice and water are activated by two different switches? The ice switch activates the motor that dispenses ice. The water switch activates a solenoid that opens to dispense water. If you can, find the solenoid and make sure it's not stuck closed (tapping it with a screwdriver handles usually help persuade it a bit). I would tap the solenoid while pushing the water button. Listen for the solenoid to activate. If you can't activate the solenoid, find the switch and depress it with a small screwdriver. Usually, these switches are just simple little microswitches that need a little cleaning and coaxing
Feb 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
3 yr. old Hoshizaki km630 mah, Had a hard freeze(24 degrees) at the shop and checked the ice maker that sits outside main bldg. Main water supply line inside that joins the copper pipe to the plastic...
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Jan 13, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Whirlpool ED22DQXEW01 Water Dispenser Problem
CHECK WATER FILTER/// IF GOOD BAD WATER VALVE
Jun 18, 2009 | Whirlpool ED2FHEXN Side by Side...
My Amana refrigerator has water and ice on the outside door. The ice works fine but I am not getting any water. I have replaced the water filter. Can you tell me what the problem is?
Did you check to make sure you have water going into the filter? Sometimes, the tiny hole used in the flow valve gets clogged at the source. Shut the valve and reopen it.
Feb 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
TFX25JRYFAA SIDE BY SIDE GE REFRIGERATOR
try taking off the dispenser front and check the "switch " controlling water /ice. its a micro switch your connecting with as you change from one to the other{ice to water) im assuming that the switch is not being activated. plungers get stuck switch gets old
Mar 11, 2008 | GE GSH25JFR Side by Side Refrigerator
I had GE come out and look at it. I wasn't home to ask questions. The repair man basically said it was a 'loose connection' in the back which is where the motherboard is for all the electronics. It took him less than 5 minutes to fix and he was gone.
Thankfully - it cost me zilch. I told a small white lie and said we were still under warranty and they didn't ask to verify. Can I get an Amen!
Oct 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
122 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
