Question about Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier
Machine is not withdrawing water.
I'm sure it is not because the basement is too dry. I bought a second dehumidifier and it worked fine.
  • Whirlpool Master
  • 43,501 Answers
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 04, 2010
Our AD25THO. Runs fine but has recently stopped collecting water. It's dry as a bone and our basement is very damp. What's wrong with it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Jun 11, 2011 | Whirlpool AD25BBR Dehumidifier
My basement has condensation in the walls, but the dehumidifier won't turn on. It is plugged in and the bucket is empty. Not sure what the numbers have to do with the machine turning on, but I have...
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Aug 26, 2010 | Haier HD656E Dehumidifier
Dehumidifier not working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
heatman101
May 13, 2010 | LG LD40E Dehumidifier
My Haier dehumidifier Model #39R171E is operating intermittently. The bucket is not full - power is on - temp in room says 59- do I increase the humidity to get it to work? Have a large amount of water in...
If your carpet is wet ... like mine was ... the best thing to do is bite the bullet and get the carpet out of your basement or where ever it is ... so your dehumidifier has a chance.
You reduce the % on the machine to reduce the humidity in your room. You should probably also get some fans going.
I have removed my carpet and padding and everything that I can reasonably remove from the room. I have 4 fans going and 2 dehumidifiers and two sump pumps. I also keep the windows open in the day time because it is more dry outside than in the basement. I have heat in the basement which I run at night. My goal is to save my house from damage due to moisture. It will be a good month for the electric company, that is for sure.
I'm sorry you are in this perdiciment ... I'm sorry for me too. My carpet was less than a year old and we have not had any water in the basement for 30 years.
Mar 03, 2010 | Haier HDN655E Dehumidifier
Dehumidifier making room very hot
Humidity, [Swetting] until the Room is totally dried out.Remember you are also drawing off infloor and underfloor dampness too.
Regards,DT
Aug 30, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Works well but
Yup, they eat energy.
An electric dehumidifier includes a refrigeration cycle that is very similar to a window AC units and refrigerators. They cool the air in the basement to condense and collect water and remove humidity, heat the air as a required consequence of the refrigeration cycle and dump it back to your basement.
Two sources of humidity in basements include warm outside air that naturally cools due to below grade earth contact and water passing from the ground though the floors and walls and evaporating into the basement. Dehumidifiers do most of the work in the summer when higher temperatures outside enable air to hold more water content.
In the winter, cooler outside air contains less moisture by weight eventhough it may be raining and the relative humidity in basement will be less because the air is warmed relative to the outside. The lower moisture content in the winter also absorbs the water passing through the walls and floor.
From an energy perspective, you may want the humidity set NOT below 50%. This will keep humidity below the level mold desires, but prevents the dehumidifier from doing more work and eating more energy than needed. A cheap battery powered temp/humidy meter left in your basement will help. Sources that include the "mold triangle" (temperature, water & food) often separate fact from expensive hype.
If the dehumidifier doesn't keep up, consider adding a moisture barrier to the basement walls and floors such as Dry-lock and floor paints to ****** moisture entry. Moisture barriers act very similar with water as insulation does with heat. They don't eliminate the need for a dehumidifier, but they reduce the work they do and energy they eat.
Oct 02, 2008 | DeLonghi DH40P Dehumidifier
Dehumdifier won't drain
You just need to get the water flowing and start the siphoning process by taking out the water bucket while it's full of water and raising it up high enough to start the water flowing. Once the water starts flowing, you can put the bucket back and the water will keep flowing (by capillary action). If the bucket empties completely, you may have to do it again periodically to get the water flowing again.
Sep 17, 2008 | Kenmore 54701 Dehumidifier
Dehumidifer seems to run constantly
With that low of a setting it will most likely be kicking in alot more often. Most people run their dehumidifiers between 60-65%. It is a matter of preference. Also some basements hold out moisture more than others. There could be alot of variables affecting this. One thing you need to make sure is that you have the correct placement. Make sure you dont keep it near the sump pump or any other standing water because those areas have more humidity due to the water being there. Also make sure it is not in an area like a laundry room because when your washing machine despenses water it is despensing moisture into the air. I try to keep it at a central location if at all possible and away from areas that have water. If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Sep 06, 2006 | LG Goldstar LD65EL Dehumidifier
Whirlpool Gold AD70USS 70 Pint Per Day Ultra Low Temp Basement Dehumidifier with AccuDry Sensing Sys... Dehumidifier Logo
1,090 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
