Question about Oster 250 Watts 2534 Inspire Hand Mixer
I have a Oster mIxmaster Model #2534. I need to purchase new Beaters for it.
The beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and do not fit in
wild guess turn beater as you push in to allow the beater to engage the drive, a little like gears meshing. You should be able to feel it lock into the drive.
Dec 21, 2014 | Oster Food Mixers
Beaters will not stay up in my Oster stand mixmaster. The eject lever will not lock them in. Can it be fixed? Or could it be that I need new beaters because they are worn out and don't fit
They need to be replaced or the locking mechanism does, but in the meantime, wind some thread around the beater end and this may keep them in temporarily.
Mixmaster is leaking oil from the beaters
Here is a link on YouTube. It may not be for your model but it can give you an idea: http://www.youtube.com/watch?v=8eKHVvNX5eY
How to Fix KitchenAid Stand Mixer That Is Leaking Oil
Apr 04, 2014 | Food Mixers
Mixmaster junior
This is an issue you will have to take up directly with Sunbeam. Be sure to provide specific model information
Aug 04, 2013 | Food Mixers
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Oster 250 Watts 2534 Inspire  Hand Mixer Logo
114 people viewed this question
Top Oster Food Mixers Experts
Ross Keen
Paul Carew
Lawrence Oravetz
Are you an Oster Food Mixer Expert? Answer questions, earn points and help others
