Question about Kenmore 82822 Electric Dryer
E 1 message dryer turns off - Kenmore 82822 Electric Dryer
Tumble dryer displaying E90 error
do you have the machine's manual ? if you do try and find out what the message mean
Mar 23, 2012 | Zanussi ZDC5350W Electric Dryer
My daughter put a large wet blanket in the dryer and it has completely stopped rotating. I can here it turning on, but not sending the message to heat and rotate the drum
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 97561 Gas Dryer
I have an LG DLEX3001R dryer. The CHECK FILTER message keeps coming up when the dryer is turned on. before it had a legitimate reason to be displaying because the dryer venting was clogged. i cleaned out...
Hard to say, what the problem might be, but I got a suggestion.
Pull out the plug for a minute or two, it might be that the sensor hung, and need to be reset by loosing power on the circuit board.
Jul 29, 2017 | Washing Machines
When I press buttons to turn dryer says lock and
press and hold the select and cancel buttons for six seconds this should reset the dryer control.also try to unplug the unit for a few mintes
Sep 16, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
Drum will not turn but it is heating up
Pressing 5 Skips introduction, or Skips to next message.
Pressing 6 deletes current message and Skips to next message.
Pressing 7 plays telephone ID of caller if provided
Pressing 8 Repeats previous message, or repeats message
Pressing 9 Pauses or resumes message
Pressing 0 exits the messaging system.
Jan 29, 2009 | Amana NDE2335AY Electric Dryer
Kenmore Elite quiet pak 9 dryer
Error message E1 indicates the temperature thermistor has failed.
Jun 22, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
MAYTAG NEPTUNE GAS DRYER
Unplug the unit and take off the cover where the cord goes in. You may have one burnt wire under that cover.
Mar 06, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore 82822 Electric Dryer Logo
97 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
