Question about HP Photosmart C5180 All-In-One InkJet Printer
C5180 All-in-One LCD screen on printer is blue and just says: C2FF8575. Printer will not respond or turn off.
  • 3 Answers
HP doesn't list that specific error code, however www. dumpanalysis.org had a crash dump analysis listing that or a similar code. That means your printer has an internal error state. Check with the HP articles for error codes. You should try shutting it off for two minutes then rebooting to see if you can get it back online. 0xC2FF, & 0x0000C2FF are UTF 16 & 32 bit Hex codes indicating a memory overflow error (from what I could judge). If you are fortunate it will not be a permenant condition from hardware failure, otherwise your printer may need servicing.
Posted on May 04, 2008
SOURCE:
My hp c5180 printer will not start up. It turns on but will not completly start up.
We were having a problem with a c7250 not starting. We were getting a blue screen on the display. After unplugging it from the wall (not to mention som gentle thumps on the desk), we finally managed to get it to boot. What fixed it for us was to get into the configuration menu using the * and # keys and then entering 123. We then choose user from the boot options. So far, so good.
Oct 11, 2010 | HP Photosmart C5180 All-In-One InkJet...
HP PRINTER C7280 ALL IN ONE PRINTER. ERROR CODE ON printer LED SCREEN- INK SYSTEM FAILURE as above code.
Getting the blue screen on the printer LCD with the on/off switch symbol and the error 824C1500. Get a new and different error message each time I unplug the printer, wait a minute or so and then re-plug it in. I responds to no button pushing and will not turn off at all. Is there a simple fix for this problem or is it a throw-away?
for more help visit https://cbrtechsolutions.net
Oct 07, 2010 | Office Equipment & Supplies
No connection to computer when I ask computer to print nothing happens
Hi
Thanks for using FixYa. As theprinter is not responding to the print command, you need to follow thestep-by-step procedure to download a utility to resolve the issueautomatically, resolve the issue manually or uninstall and reinstall the HPsoftware from the following link---
HP Photosmart C5180 All-In-One Ink Jet Printer not printing
Please do rate the solution andrevert for further assistance.
Thanks
Rylee
Sep 15, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp c5180 printer: While printing a job, the
it sounds like the printer is malufunctioning...it might be a problem with the printer head..see where the printer opens for the ink.. look at the yellow space for the ink.. remove the ink and take a cotton swab full of alcohol and clean it then let it dry and place the new ink cartridge there and restart the machine..see if it gives the same eror..if it does consider replacing the device
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Jul 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Blues will not print
Printers are not repairable because you can purchase a new one for less money. I recommend buying an Epson all-in-one printer when it is on sale. A really nice one can be bought for less than $100.00.
May 27, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 will not print in blues
try to run maintenance pages..go to your printer panel ..and choose maintenance..and print maintenance page..
May 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scanner problems
You need to have the full photosmart software loaded on the computer and to use this to scan to computer rather than using the buttons on the printer. This is a workaround rather than a fix but it should work
Fred
May 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 Inkjet Printer
maybe..can you remove the software from the control panel(uninstall) ??
if so, do that, and then go here for fresh set of drivers.
re install
see how that goes.
Mar 27, 2008 | HP Photosmart C5180 All-In-One InkJet...
Message on the LCD
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
Jan 06, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
293 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
