Question about Samsung HLP4663W 46" Rear Projection HDTV
Timer light is flashing on front panel. Manual
Timer light is flashing on front panel. Manual says a cooling fan may be bad. Which fan could it be?
    Problem Solver:
  • 17 Answers
If you know your way around the inside of the set, take the back off, Plug in the set and watch to see if the fans fire up, do not touch anything in the bacjk while the set is on, remember your just looking. Now if you have a good visual you may also be able to see if there is lots of dust build up in or around the fans, if so unplug the set and carefully use a portable vacume on each fan, plug it in and see if that helped, if not replace fan, if you can see which one that needs to be replaced, failing that call a tech.
Posted on May 04, 2010
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Why won't the fan motor shut off on my 1991 acura legend?
Hey chandralebea,
Try first by replacing the cooling fan engine temp sensor switch, as this may be the cause.
Good Luck
Jul 29, 2012 | 1991 Acura Legend
Washer will not spin or ajatate. I need to remove the front panel to see what up?
Use downwards force to relieve tension on the spring clips holding that front panel on.themobilian_1904.jpg
Video how to:
Once yall have the front panel removed yall will notice the motor has a green blinking light on it.
The motor blinks on and off all the time It blinks faster when running. That is normalment mon ami.
If it ain't acting right it will display flashes:
1 flash bad motor
2 flashes slipping belt
3 flashes corrupted software bad motor
4 flashes failed mode shift circuit
5 flashes little green men (bad motor)
6 flashes locked motor check for objects between tub
7 flashes bad lidswitch.
8 flashes motor overheated too much soap
9 flashes brake resister is toast bad motor.
To Reset the Inverter Board: Push the timer knob in so the washer is idle. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds.
After resetting the inverter board, put the machine in a spin cycle and see if it runs. If not, check for a green blinking light on the inverter board. It will flash failure codes according to the picture above. If no light you probably have a blown fuse built into the neutral side of the harness on the white/red wire.themobilian_26.pngthemobilian_27.png
Service manual and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 16, 2011 | GE Profile WPRE6150KWT Colossal Capacity...
I have a Friedrich MW18Y3F unit. It's not heating this morning but the operation light and timer light are flashing together 5 times and then the timer light flashes a 6th time by itself. On line manual...
Try the reset at the unit and see if the fan tries to engage at all. Also check the wiring connections between the indoor and outdoor units. If it does not then you either have a bad fan motor or the control board is bad.
Jan 30, 2011 | Heating & Cooling
Fijitsu wall mounted split system operation and timer lights are flashing, and the air con is not blowing cold air, only like fan operating even in cool mode.
This the common problem with all a/c holders. Without knowing the function of Timer on and Timer off, if it's pressed the unit will start only at setting time.
Please remove the battery from your remote and reset it. And then with use of your manual, set the timer if you need., otherwise normal function will be activated.
Dec 11, 2010 | Fujitsu Heating & Cooling
Rs21 samsung twin cooling
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Sep 14, 2009 | Refrigerators
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
237 people viewed this question
Jerry Greenberg
Jerry Greenberg
