Question about Whirlpool Washing Machines
Whirpool awo/d 4505 washing machine making grinding noise
I have a whirpool awo/d 4505 washing machine. It stopped working just after we moved house in feb. The pump was just making a chugging noise and it wasnt doing much else so we cleaned pumped out and rinsed it through like it said in instructions. Now it has started to make a scrapy, grindy metallic noise when it turns like when a metal zip is being dragged around it. The noise is on and off when it turns and the machine has got louder when it spins. I have cleaned the pump again today (just let it drain and checked there was nothing blocking it) but it is still making the same noise. There are no warning lights on the front of the machine. Is there a problem with it? I know its not broken down yet but we really cant afford a new washer (or to flood the flat downstairs!) and hope if it is broken we can get it sorted before this happens.
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
  • 109 Answers
SOURCE: series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Posted on Jun 16, 2009
reddyanantha
  • 205 Answers
SOURCE: i need to clen the pump on a whirlpool washing
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Posted on Sep 22, 2009
Testimonial: "cheers man , great help prob solved. "
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
Posted on Mar 13, 2010
SOURCE: how to reset service ligth
whirlpool awdo/d 4505 flashing service light
Posted on Feb 03, 2011
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
I need to clen the pump on a whirlpool washing machine awo/d 4505
Sep 22, 2009 | Washing Machines
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
