Question about Dishwashers
I have an Electrolux dishwasher model DX102SJ*02. One of the roller assemblies that hold the top tray on the rails has broken causing the tray to droop. I would like to know what part number I need and where I can get it. I live in Darwin NT, Australia.
Sir/mam
try www.partnship.com.au
Posted on Apr 17, 2008
    Sergeant:
  • 351 Answers
If you ring electrolux spare parts they will post out to you.
Posted on Mar 26, 2008
    Guru:
  • 93 Answers
Is it possible you could post an Image of the rollers? I tried looking up the model # at my parts distributor and had no luck. Its possible that an image of the rollers could help, or at least double check the Model #.
Thank you
SOURCE:
My Dishwasher door keeps springing open - how do I fix this?
seems like it should have a lock on it someplace to keep door shut while operating .
May 16, 2015 | Dishwashers
While the washer is on and the water starts the door opens how to fix this? thanks
Hello Shirin;
My name is Peter. I am a retired field service appliance technician.
Push in the top and bottom trays. Close the door. Now, open the door. Are either the top or bottom trays pushed out?
In the bottom center is your water distribution vanes. Are they stuck up in the operating mode? Push the center water distribution vane down, push the top and bottom trays in, close the door and reopen. Are the upper or bottom tray sticking out? inspect the guide rails. Is there something blocking them?
So, your problem is:
1.) The trays are pushing against the door because they will not go in all of the way.
2.) You have a broken latch assembly.
You did not provide a model number. This is on a tag either on the top of the door or on the face of your dishwasher after you open the door
May 16, 2015 | Frigidaire Dishwashers
Electrolux ewdw 6505error code "02"
Owners manual. Will be in the back. Google is your friend
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Jun 06, 2014 | Electrolux EWDW6505GS Fully Integrated...
How do you raise the top rack?
Refer the user guide!
Look at the rails on both sides, probably you will get an idea. There will be tray guiding rollers also.
May 27, 2010 | Maytag MDB4621AW Built-in Dishwasher
The left side of my top tray has come off the rollers. How do you reinstall?
Lift the side closes to you up and the front side with roller down into rail slot and slide it in.
Apr 17, 2010 | Electrolux Frigidaire Professional Series...
I can't put back the top dishwasher rack. The railing does not seem to hold it, even though there is no damage in the railing. The top rack could not be held by the rollers
There should be plastic stops at either end of the rail that prevent the rollers of the rack from coming out of either end.
Sep 22, 2009 | Maytag Dishwashers
GE Nautilus top roll out tray
Although most GE roller assemblies are universal...you will need the model....#...(which you will find on the inside of the washer on the wall of the drum).....but here is a part number and the link to get exactly what you need
Item #
2287
http://www.repairclinic.com/GE-Dishwasher-Parts?s=a9b3
this should get you going this place is great I have used it many times....and fair pricing.....
Good luck, good day....and thank you for rating my effort....The Fang.
Mar 19, 2009 | GE Nautilus 24" Built-in Dishwasher
I can't reatach top( glasses) rack I can't figure out where the clips go into.
The clips attach to the upper tray assembly...you clip the little roller assemblies (all one piece) onto the bottom of the tray...along the lowest part of the tray...when clipped in place...(I'm not sure but there will be an even # on both sides) you then put the tray back into place and it will roll inside or along a silver track...which may have a slot cut out where the rollers drop down into and then the tray is pushed back...into place and the last roller drops into the slot and the tray will extend along with the arm that the rack is sitting in/on.
I hope this helps...any more ??...just ask....good luck...thanks for rating my effort...The Fang.
Feb 19, 2009 | GE Nautilus 24" Built-in Dishwasher
HP Laserjet 4100 series , paper jam output tray.( on top of the printer ). The roller under the topcover is turning the wrong way. The paper can't get out of the printer, and jams between the upper roller...
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Nov 18, 2008 | HP LaserJet 4100 Printer
Top Tray clips on diswasher broken
I have the same problem and there is an inherent design flaw. You can normally buyt these at most outlets, however you can buy more than 4 to support the tray, or I have cut a small diameter aluminium tube (1/4" diameter) and threaded it through the tray from the side and into the sliding rails. It is not an ideal solution, but will last a lot longer than the silly grey wheels! Doi two bits ( one at the back and one at the front.) You have to play around a bit to get the drawer to move in and out, but it is much stronger than before. Good luck Charles in Australia
Aug 17, 2008 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
131 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
