FixYa.com
Tags:
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Model D52W208
posted by Ronald5150 on Mar 26, 2008
I've had the TV in Mexico and there have been alot of power cuts due to people stealing portions of power lines for the copper. I believe this might have caused a problem for this system.
It doesn't turn on, it doesn't do anything. Any suggestions.
Ron
Comment by Ronald5150, posted on Mar 31, 2008
Can you tell me where the main fuse is located?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 26, 2008
Helpful (85)
willtab
Rank:Guru Guru
Rating: 89%, 339 votes
ok so it shows no light blinking on front? ,.... when that happens first thing to check is main fuse... power fluctiation may cause it to blow.
Comment by willtab, posted on May 13, 2008
the main fuse is located on a small board in front of the main green board.. if you follow the power cord to where it ends inside the set then the fuse is close by.. CAREFULL televisions can generate potentally lethal voltages.. even when unpluged...
Rating Locked! (?) Ronald5150 has rated this solution as Helpful
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection HDTV-Ready...
no tv picture or sound
green power button cycles 3x... Answer This...
PICTURE TO LARGE FOR THE SCREEN...
I can;t get the zoom bottoms to... Answer This...
**** tv
ghosting red, blue, green. Red,... Answer This...
green light flashes
tv worked fine when shut off... Answer This...
damn tv
there was a post up top that... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
