Question about Gaggia Titanium Espresso Machine
Gaggia Titanium that continues to Steam.
I also have a Gaggia Titanium that continues to steam after the control knob is closed (and opened & closed etc..) Eventually it will stop after multiple twists of the knob. I have only seen this May / June 2009 posting. Do I indeed need a new wand?.. It seems to me that it is a valve that needs replacing.
    President:
  • 1,618 Answers
You need a new valve. Try getting the stainless steel valve assembly.
Posted on May 03, 2010
After decalcifying our Gaggia coffee machine and it going through its rinse the messages says rinse finished close knob. The knob is closed but the message stays and the machine cannot be used as its...
A frequent problem with some of these is that the internal switch loosens up. It is a micro switch positioned so that the steam knob contacts the switch when you close the knob fully. You can try pressing in on the knob while you turn it closed and that will usually cause it to contact the switch and get you going again.
It will likely happen again and if it does you may want to open up the machine (if you are very handy with that sort of thing) and get the switch securely positioned so the steam knob closes it reliably.
Dec 13, 2010 | Gaggia Titanium Espresso Machine
Steam not working properly = keeps saying close knob then ventilate have waited and pressed 26 + does coffee but then steam not strong enough again
Probably a broken "Steam Valve Cam". They are plastic & prone to failing with consequence that the steam/hot water needle valve does not properly open.
May 05, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
Gaggia Titanium coffee maker leaking water internally from steam tap
What color is the steam manifold? It is located under the black cover with the trough in back under the white tube. If its white or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand. But its going to have to be replaced.
If it is silver you probably have O-rings that need to be replaced. I would use the black O-rings, not the red. The red ones are a little smaller and can leak.
Dec 01, 2009 | Gaggia Titanium Espresso Machine
Can't get rid of ventilate message on titanium plus machine
Try this, after opening hot water valve, push the knob in when it asks for ventilate. If that works then contact your nearest gaggia distrubutor and ask for a new stainless steel steam valve assembly.
Jul 04, 2009 | Gaggia Titanium Espresso Machine
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Stema Knob wont fully stop flow of steam/water
Here is the link to the part that you need to change. http://cerinicoffee.com/Saeco_steam_valve_plastic_italia.asp
For Saeco Parts and Cleaning supplies visit www.cerinicoffee.com
Jun 18, 2008 | Gaggia Titanium Espresso Machine
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
245 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
