Question about HP LaserJet 3015 All-In-One Printer
Fuser removal instructions, hp laserjet 3015 - HP LaserJet 3015 All-In-One Printer
  • 33 Answers
Here is a link to the Service Manual for this machine. This should give you the info you need.
Larry
http://www.savefile.com/files/1919671
Posted on Dec 07, 2008
3 Suggested Answers
zohail
  • 1223 Answers
SOURCE: HP LaserJet 3015 All in One
simply scan the document using cable connected to pc but u first need driver for scanning thru ur HP machine and then when u saved ur scanned image u can manually attach the file at ur mail server like yahoo or msn by using attach files option or u can also do it directly if u use MS Outlook Hp can scan the image and directly attach the file to ur new email message to be sent
pls first
Install the drivers from CD that came with it
then open up the HP software like HP solution Centre and then try to scan the image but u need cable for that
and select scan to email option there if available
here is the manual of ur HP machine kindly RATE ME WELL !
Manual
Kindly see here for the SCAN EMAIL SETUP
Posted on May 19, 2009
vinay229229
  • 1121 Answers
SOURCE: 50 fuser error in hp
Error 50.xx indicates Fuser faulty, replace it..
Posted on Sep 14, 2011
50 fuser error in hp laserjet 3015 all-in-one
Sep 14, 2011 | HP LaserJet 3015 All-In-One Printer
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
How do i removed the fuser unit in my hp 3015 printer
Removing the Fuser in a HP 3015 printer is a delicate task that requires a lot of the printer to be disassembled. This type of repair is not recommended for anyone who is not well-versed in technical repairs. Because it is not an easy task to complete, the manufacturer (HP) does not recommend end-users performing such a task, as it is easily damaged and is not designed to be repaired.
However, if you wish to attempt the repair anyway, here are some instructions for how to do it: Fuser sleeves come with NO instructions, but you will need to remove one plastic guide that is held onto the fuser with a single screw. Release the two pressure springs, and then lift the assembly with the sleeve free on the non-gear end. Remove the black plastic guide from the end (gently pulling) and then slide the old sleeve off. Slide the new one on, and reinstall the black end-cap. Next replace the assembly, springs, and guide, and the refer back to the manual for reassembly. Although there does not seem to be any videos for performing the replacement fuser in an HP 3015 printer (Online), here is link to a similar printer manufactured by HP that may help with understanding how to replace the fuser.
http://www.youtube.com/watch?v=1ZMGvjbjhVk&feature=player_detailpage
Jul 19, 2011 | Computers & Internet
I want a manual for changing fuser om laserjet 3015 aio
The manufacturer's web-site:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=378048&lang=en&cc=us
contains all the available documentation and trouble-shooting guides for your printer.
I don't see a "service manual" that would describe your task, but you should look for yourself.
Nov 19, 2009 | HP LaserJet 3015 All-In-One Printer
HP Laserjet 3015 - Printed pages are VERY light
Printed pages are VERY light, and the fuser temperature is low. The toner is not fixed on paper. Still it don`t give any errors. A detailed diagram of the power souce have anyone?
Nov 13, 2009 | HP LaserJet 3015 All-In-One Printer
HP 3015 Laserjet paper jam error message
The paper is probably jammed between the fuser and the rear cover if you can't see it.
Aug 18, 2009 | HP LaserJet 3015 All-In-One Printer
HP 3015 laser printer with ghost image
A fuser image should only be about 1 1/2 inches away, 3 inches sounds like a drum problem.
Aug 03, 2009 | HP LaserJet 3015 All-In-One Printer
Printer wont work
try to remove cartridge and look down in to printer, use flash-light or lamp to find. Also chek fuser unit ( exit unit) from paper.
Mar 03, 2009 | HP LaserJet 3015 All-In-One Printer
Hp LaserJet 3015 Printer.
is it wavy? if so then it is either the toner cartridge or the fuser unit (heat section) I would go for the fuser unit as the hot roller that makes the toner stick to the paper is only a plastic film. Have you noticed any gray pieces of plastic coming out?
Hope this help you and you can get these machines repaired also please rate me
Cheers J
Dec 28, 2007 | HP LaserJet 3015 All-In-One Printer
HP LaserJet 3015 All-In-One Printer Logo
2,509 people viewed this question
Seeker5211
Seeker5211
