Question about Dell (E210882) Motherboard
Thermal protection override. My motherboard went into thermal protection override and will not post. I have cleaned it and now how do I reset it?
  • Clarker Mar 26, 2008
    I reset the bios, attempted reset on cmos, no effect. Removed the cpu (DELL e210882 SOCKET LGA 775 MOTHERBOARD ) and reset with silver paste, still no go. No reset button available. Ant other ideas other than a board replacement? Thanks !
    Novelist:
    Champion:
  • 236 Answers
Tyou should find you rmanual and find the reset button or jumper. You must also try to find out what went wrong first why it went on thermal shutdown. You have to resolve the problem first. It could still be there that's why it wont post. If you know how to changes all your cmos.bios settings then if you can not find the reset jumper or switch you can actually reset your cmos to default factory setting. be careful though because you haver to know all your settings, the dates as well for your software activation. i suggest that you remove first the connection of your hardisk until you get your board running then put it back. do not boot your hard disk with the wrong date in your cmos. it will corropt your softwares specially virus protection
redrivera
Posted on Mar 26, 2008
  • Redentor Rivera Mar 27, 2008
    it's only a matter of determining wether it is your CPU that got damaged or your main board. If it is thermal trouble it is possible that the CPU is the defect but you can just do a trial and error now to determine which is deffective. if you can find a termporary replacement for both the board and cpu. but please clarify how did you reset? did you find the jumpers if no switch? when you say reset that would mean putting back the cmos bios to factory default. if you did not find the jumper to reset then you did not really reset the system. remove the battery and leave for at least 5minutes. that will also reset the system.
Automatic thermal protection reset does not occur. Shredder rendered inoperable. Red LED stays lit. What can I do to reset it?
Hi Jeffrey, Sounds like the thermal overload protection is shot. I think that you should be able to get a replacement from radio shack or similar.
Apr 20, 2015 | Fellowes Powershred P-58cs, 9 Sheet...
Car will not start
depends on context , not stated.
cars use many technologies.
one is Electrics and electronics.
thermal protection in this context means.
1: fuses.
2: fuseable links (looks like an odd splice in a wire)
3: Circuit brakers.
all 3 stop the fire.
The cars battery can source easy 500 Amps and can make a fire fast. these fuses stop that fire.
also electonics have air cooling or devices that keep the parts cool
this too is thermal protection'
so why ask this. why not say here you saw it, so we can understand
the CONTEXT.
Feb 15, 2014 | 1996 Honda Accord
Thermal event
YOUR COMPUTER IS TO HOT YOU HAVE TO CLEAN IT FROM DUST AND OTHER PARTICALS.USE A CAN OF COMPRESSED AIR.THE COMPUTER SHUTSDOWN FOR PROTECTION.
Nov 29, 2013 | Intel Computers & Internet
Malfunction
Error 1 is a defect in the steam heating unit.
Possible solutions:
Thermal sensor is defective -replace.
Cable to the thermal is broken or contact pins are corroded - replace, repair.
Heating or thermal cut-out are defective - measure and replace parts if required.
Triac on the power board is defective. The heater heats up triggering the overtemperature protection - Replace the overtempereature protection (thermal cut out) and the power board or the single triac.
Oct 08, 2013 | Jura Capresso Impressa F9 Espresso Machine
CS-W12DKR indoor fan motor thermal protection?
Thermal protection on motors is inside the motor and is supposed to reset when the winding cools down. There may be a red button reset on the exterior of the motor. The thermal protector consists of one or more heat-sensing elements built into the motor or motor-compressor, plus an external control device. The thermal protection is present to turn the motor off when excessive heat is generated within the motor circuitry, halting the temperature climb before it can burn up the motor.
Mar 30, 2017 | Carrier Heating & Cooling
Red light flashing, and how to reset to standby ?
red flashing light usually means that the receiver is in protection mode and it has a hardware problem like burned channel or bad power supply or thermal protection, etc. For some receivers/models (you didn't mention your model) you can override this protection but the receiver can get more damages. So, better to bring it to a service center for diagnosing /repair. Thanks, ebcelectronics
Nov 17, 2010 | Audio Players & Recorders
Looked and the thermal fuse is not broken
check again thermal fuse that you replace maybe wattage is not enough. there a lot of protection in that circuit.
May 30, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Dryer will not get hot blows cold air
Usually it's one of the thermal protection devices attached to piping inside the dryer. I usually see 75% thermal device failure and 25% heating element problem. Thermal protection devices are also very cheap. Is this a gas dryer? If so it could also be the ignightor. Do you or a friend have a simple meter to measure things with?
Jan 22, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Dell (E210882) Motherboard Logo
202 people viewed this question
Alun Cox
