Question about IBM ThinkPad R52 Notebook
IBM R52 Model 1860, CPU: Intel Pentium M 1.86 GHz, OS: Windows XP SP3, Memory size: 1.5 GBytes Problem description. 1. With battery in: a. At times the laptop turns itself off (does not seem to be an overheating problem, it has been tested with heat imaging instrument); root of problem is unknown b. Once it is turned off, it can not be again turned on unless the battery is removed AND the AC adapter is disconnected; then re-insert the battery OR reconnect the AC adapter (either or both) c. The laptop now can be turned on 2. With battery out: a. At times the laptop turns itself off (does not seem to be an overheating problem, it has been tested with heat imaging instrument); root of problem is unknown b. Once it is turned off the laptop can not be turned on again c. The AC adapter now has to be disconnected d. The AC adapted has to be reconnected e. The laptop can be turned on 3. Conclusion: it seems that when the laptop turns itself off (reason unknown) all power (both battery and AC adapter) has to be removed; then one or both types of power need to be reconnected; then the laptop can be turned on. The removal and reapplication of power seems to reset something and as a result the laptop again can be turned on.
  • Steve Fekete May 09, 2010
    The suggestion (remove all power sources and hold the power button for at least 30 seconds)seemed to be helpful but only solved half of the problem. Now I do not have to remove all power sources when the PC turns itself off. I can restart the PC normally. However, the PC still turns itself off and I feel that this is and was originally a separate problem from the following scenario:
    remove power-->reconnect power-->start PC
    As I said, the PC still turns itself off as before but I do not think this is caused by overheating (see my earlier post).
  • 177 Answers
Try this: Remove the battery and AC power, press and hold the power button for at least 30 seconds and then put both back in and start it
Posted on May 09, 2010
Install windows xp drive cd
Probably, if you cannot instal your OS and your disc is not damaged, you have hard drive errors stopping installation of the OS. I would replace the hard drive. It may have memory issues so I would also google the error code for more information.
Dec 24, 2013 | IBM ThinkPad R52 Notebook
I install Burnout paradise the ultimate box and got an error when try to play the game... this machine gpu does not support shader model3 which is required to run this game. I have Intel(R) G33/G31 Express...
you must upgrade your graphic card. the problem as nothing to do with your chipset. This are the minimum requeriments to run the game:
OS: Windows XP/Vista
Processor: Intel Pentium 4 @ 2.8 GHz / AMD Athlon 64 3000+
Memory: 1 Gb
Hard Drive: 4 Gb free
Video Memory: 128 Mb
Video Card: nVidia GeForce 6600 / ATI Radeon X1300
Sound Card: DirectX Compatible
Network: Broadband Internet Connection for Online Multiplayer
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Recommended System Requirements
Processor: Intel Core 2 DUO @ 2.5 GHz / AMD Athlon 64 X2 5200+
Memory: 2 Gb
Video Memory: 512 Mb
Video Card: nVidia GeForce 8800 / ATI Radeon HD 2900
DirectX: 9.0c
Keyboard
Mouse
DVD Rom Drive
Aug 26, 2012 | Computers & Internet
Says my system is not suported
These are the system requirements for the M-Audio Fast Track USB input. Be sure that you meet these requirements, or else upgrade your system to meet them.
MINIMUM SYSTEM REQUIREMENTS-FAST TRACK HARDWARE Windows
  • OS: Windows Vista 32/64 or Windows XP (SP3) Home or Professional
  • CPU: Pentium 4 2.0GHz, 1 GB RAM, 1 native USB port
Mac
  • OS: OS X 10.4.11
  • CPU: G4 (native), 1 GB RAM, 1 native USB port
MINIMUM SYSTEM REQUIREMENTS-PRO TOOLS M-POWERED ESSENTIAL HARDWARE Windows
  • CPU: 1.8GHz multi-core (Intel or AMD), 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mac
  • OS: OS X 10.5.5 or greater
  • CPU: 1.8GHz Intel multi-core, 5400RPM drive, DVD-ROM drive, 4 GB hard drive space (additional space required for loop content)
Mar 11, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
Will an Intel® Pentium® M
I don't know your exact CPU specs but I've taken a single core Intel M processor 2.0 GHZ from a Dell 800 laptop and put it into my wife's X1000 and have had no problems running XP SP3. My own x1000 computer reports Intel Pentium M 1600MHZ as CPU type.
Dec 22, 2010 | Compaq Presario X1000 Notebook
Mi problema es con el ciberlink powercinema 5, cuando lo abro la tv se escucha pero no se ve y se queda pillado el ordenador, tengo windows xp sp3 pro.
It can be the TV Tuner Card.See this:
Operating System
  • Microsoft Windows 7, Vista and XP SP3* (Windows XP Service Pack 3 is required)
Processor (CPU)
  • Blu-ray Disc playback: Pentium 4 541 (3.2 GHz), Athlon 64 X2 3800+ or above
  • TrueTheater 3D playback: Pentium D 950 (3.0GHz), AMD Athlon 64 X2 3800+ or above
  • DVD playback: Pentium 4 (2.4 GHz), Athlon 64 2800+ (1.8 GHz) or above
Graphics Processor (GPU)
  • Blu-ray Disc playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 7600GT or above
  • TrueTheater 3D playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 8800GT or above
  • DVD playback: AGP or PCI Express graphic accelerator supporting DirectX 9.0 or above
    • Note: we strongly recommend that you update your graphics card driver to the latest version. 3D display devices are required for TrueTheater 3D playback.
Memory
  • Blu-ray Disc playback: 2 GB required for Vista and Windows 7; 1 GB required for Windows XP
  • DVD and TrueTheater 3D playback: 1 GB required for Vista and Windows 7; 512 MB required for Windows XP
Hard Disk Space
  • 300 MB for product installation
Display Device
  • DVD and Blu-ray Disc playback: HDCP compliant display for digital output. TV or computer monitor for analog output
  • TrueTheater 3D playback: 3D display and 3D glasses required. HDCP compliant display for digital output. TV or computer monitor for analog output
Disc Player
  • Blu-ray Disc playback: BD-ROM/BD-RE or Super Multi Blu combo disc drive
  • DVD and TrueTheater 3D playback: DVD-ROM, DVD+-R/RW, DVD-RAM or DVD Super Multi combo disc drive
Microphone
  • A microphone is required for recording voice-overs in Movie Remix mode
Internet Connection
  • Internet connection required for web services
Dec 20, 2010 | Microsoft Computers & Internet
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Oct 18, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
IBM ThinkPad R52 Notebook Logo
321 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
