Microsoft Wireless Notebook Optical Mouse 3000 suddenly stopped working. It does not respond at all but the internal mouse pad still works. I have tried changing the battery, but that has not solved it.
  • rmurfin602 May 03, 2010
    I already tried that, and a restart, but it did not work. However, the problem has suddenly solved itself, possibly because I ran Ctrl-Refresh on my web browser.
    The problem is solved, so I do not need need a solution now.
    Please let me know whether I am still required to pay for this solution. If so, then I will accept the solution.
    President:
  • 1,561 Answers
Have you restarted your system, if you have, why don't you move very close to your system to see if it will make a difference, because it is possible that th distance could be too far for your system to detect it.
You can also remove the battery and stay for a while before putting the battery back for the circuit panel to cool down.
After putting the battery, wait for some minutes before you now use it, it could just be a problem of the panel that needs to cool.
Also check to see if you have not mistakenly disable your mouse from your system.
Take care.
Posted on May 03, 2010
  • 1,170 Answers
Try the following :
1. Move the mouse closer to the "receiver", so that there is a strong wireless signal between the two devices. Then try to connect.
2. Make sure that the mouse reciver is plugged in properly and is detected by the PC.
WHY did my Microsoft Wireless Optical 3000 mouse stopr working?
first of all you can check the cell of your mouse. after that go to start programs then system then hardware device manager you can check all the driver are installed. if driver is not installed then update the drive. you can go to start settings then system then hardware device manager and update the drive.
Aug 25, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse stopped working (Microsoft optical notebook 3000 mouse)
YOur mouse needs to be paired with the transceiver. THere is normally a button on the part which goes inot the laptop. Press it once then flip the mouse and press its button once. It will then work hopefully :)
Aug 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
Left button works. right stopped working how do i get it to work again? thank you
just open carrefully the cover and ussually only lose or broken knock button inside
Apr 28, 2009 | Microsoft Wireless Notebook Optical Mouse...
Mouse works perfecly well for couple of minutes then stops.
try a new batteries most likely it is the batteries and sorry to hear about this issue
Apr 15, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Op. Mouse 3000 Dosent work.
try plugging the usb adapter into a different usb port of the computer and there must be a connect button on tat adapter..press the connect button on tat aadapter and then press the connect button on the mouse {after replacing the battery}.if it doesnt work on 1st go ,,try 2-3 times,,,and hey best of luck
Apr 14, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
Mar 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Notebook Optical Mouse 3000 not working
Most devices last a long time. Have you tried re-installing the software for the keyboard & Mouse> Also go to microsoft download center and get the latest drivers for you setup. Make sure when you do, choose the right Operating System driver for your Keyboard & Mouse. Hope this helps. Bud
Dec 30, 2008 | Microsoft Wireless Optical Mouse
Microsoft Optical Wireless Mouse 3000 MSK 1056 does not work !
I fixed an MS wireless mouse that was not responding by pressing the button on the receiver while it was connected to a USB port & then pressing the button on the mouse. Worked fine after that.
Dec 23, 2008 | Microsoft Wireless Notebook Optical Mouse...
Microsoft Wireless Mouse and Windows Vista
I'm having pretty much the same problem with my Microsoft Wireless 4000 mouse and my hp-compaq 8510p laptop. If I shut my machine down, or restart, my mouse no longer works. I have to uninstall/reinstall the Intellipoint software. The synaptics touch pad continues to work, but the mouse fails.
Dec 19, 2007 | Microsoft Wireless Notebook Optical Mouse...
Computers & Internet Logo
David Payne
David Payne
