Question about Dell Dimension 4600 PC Desktop
Cannot play movie or hear sound on selected DVD's. in some cases i cannot use function fast forward or rewind. when i give command to do so, pc frozes it and manual reboot needs to be performed. what can i do?
  • 236 Answers
1. Update all drivers for your DVD Drive.
2. Try a different software program.
Posted on Mar 26, 2008
Model mp820 mp3 player. how do I fast forward?
Cheapo MP3 play with rewind and fast forward - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1687936
Digital Spy Jul 5, 2012 - 13 posts - ‎2 authors
Cheapo MP3 play with rewind and fast forward Tablets and e-Readers. ... can anyone recommend a cheap MP3 player that will allow you to fast forward, ... the yepp yp55 t had a wonderful "scroll through" function that took ...
Oct 20, 2015 | Coby Audio Players & Recorders
VCR needs to be tipped in order to rewind, play, or fast forward.
Sounds like an idler wheel problem on reel table of vcr. Could be loose or maybe spring is stretched or broken.
Aug 29, 2013 | Magnavox ZV420MW8 DVD/VCR
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
How do you view a movie on the camera itself
This is explained on page 68 of the manual. After selecting the picture/movie, use the 4-way control buttons. Up for pause/play. Down for stop. Left for rewind. Right for fast forward. Use the zoom lever to adjust volume.
Aug 12, 2009 | Cameras
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Sound and video playback do not match
No button or any control to rectifier this problem. Depend the movies quality when you fast forward the system control and audio video processing or it call out MPEG2 chipset they run like double speed sometimes it not fast enough then you end up with sound and video not SYNC however you can fix that by remove AC lead for 30sec then plug in back now it should work OK or when you fast forward use X8 or X16 NOT X32 times specialy with DVD copy
Alternatifly if your DVD player still under warranty it might have a update firmware to correct this problem
Cheers
Nov 01, 2008 | Philips DVP5140 DVD Player
How do I put video's on to the the media player nextar ma715?
Movie
Press rewind button or fast forward button in main menu to select Movie function and press play button to enter Movie play.
(1) This player supports the playing of movie files in SMV format. Convert the desiredmovie(MPG,AVI,WMV format) to SMV format with transcoder software(video2smv.exe)in the attached CD (if any) or save in the player or downloaded from Internet.
(2) Movie should be put in MVIDEO folder of the player. If there is not such folder,please create one. Please note that the player cannot find those movie files if theyare not put in MVIDEO folder of the player.
Here is the Website for it. It has the PDF manual and the convert software.
http://www.nextar.com/frontend/proddetail.asp?pn=MA715&co=10000309
Hope this helps. M~
Apr 30, 2008 | Audio Players & Recorders
Foot pedal
If you cannot play, rewind or fast forward, but you hear a light "click" coming from the cassette compartment, then more than likely you have a broken drive belt, or the circuit controlling the play and/or rewind/ff mechanisms are out. In either case it sounds like you need to send it in or take it somewhere for repair.
Nov 04, 2007 | Dictaphone 2740 Desktop Cassette...
Dell Dimension 4600 PC Desktop Logo
Alun Cox
