Question about GE DBXR463EBWW Electric Dryer
Can i switch the plug on my dryer
I have a 4 prog plug on the dryer need a 3 prog
    Novelist:
  • 145 Answers
If you change the plug on your dryer to a three prong and plug it in that way it will work, however it will not be up to the latest electrical codes where the dryer needs to have its own ground, not share that ground with a neutral. I would recommend running a new wire 10/3 with ground with a new four prong outlet (note: if you already have the 10/3 wire there you can just as easily change the outlet; red and black are hot wires, white is your neutral, and the bare copper is your separated ground) . However if you would like to just change the plug to a three prong you have to make sure your ground bar is tied to your neutral bar and there you only have three wires, 2 hot and one neutral.
Posted on May 03, 2010
How do i change the admiral dryer plug from 4 prog to 3 prog
why do you need to change . .4 prong is mobile home plug .3 is standard home wiring
Oct 04, 2015 | Admiral Dryers
Turn ringer on
To set the Vtech T2326 ringer:
there are only four ringer tone/volume choices plus "off" available
1. Press the PROG end of the "SELECT/PROG" rocker switch.
The display will light and show "DIRECTORY"
2. Press the right side top button "VOL +/DIR"
The display will change to "SPEED DIAL"
3. Press the right side top button "VOL +/DIR" again The display will change to "RINGER: [number] ( 1 - 4 or OFF )"
4. Press the SELECT end of the "SELECT/PROG" rocker switch.
The "RINGER: [number] ( 1 - 4 or OFF )" will blink and the ringer will sound.
5. Press the right side top button "VOL +/DIR" The display will change from "RINGER: 1" to "RINGER: 2" and the sound will change accordingly.
6. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 2" to "RINGER: 3" and the sound will change accordingly.
7. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 3" to "RINGER: 4" and the sound will change accordingly.
8. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: 4" to "RINGER: OFF" and the sound will cease accordingly.
9. Press the right side top button "VOL +/DIR" again. The display will change from "RINGER: OFF" to "RINGER: 1" and the sound will change accordingly.
10. ...and so on, cycling through the four choices & OFF: when you decide to select one, press the "SELECT" end of the central "SELECT/PROG" rocker switch.
11. The display light will go out, the phone will chirp in acceptance, and it will be ready to use the chosen ringer. --
Sep 07, 2013 | Vtech T2326 Cordless Phone
Currently wired for 3 prong plug I need to switch to 4 prong, how do I do the wiring?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 25, 2011 | Dryers
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 04, 2011 | Maytag Dryers
Warning C 08 how to reset?
Hold down on/off and prog 2 for 5 sec.
display ``fac``
Press prog 2 until display ``ron``
Press prog 3 until ``c8 / 1 or c8/3.``
Press prog 1 until ``c8/0``
Press prog 3 until ``ron ``
switch off -switch on and o.k.
General
C8 caused from glogged jets or rinse pump problem or bad luck.
If there is a problem at the dishwasher then c8 will appear again
Hope I helped you
kostas
Jan 26, 2011 | Zanussi 24 in. LS6E Free-standing...
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 03, 2010 | Dryers
I have a 4 prong pigtail
Here is what I believe you have.
The 3 prong plug on your dryer is configured with 2 lines of power and 1 ground. The 4 prong receptical is 2 lines of power, 1 neutral, and 1 ground.
You will have to turn off the breaker to see how the receptical is wired by pulling it out and looking at it. You can then buy a 4 prong plug to match it and only wire up the 3 prongs you need for your dryer and leave the 4th prong empty.
Good Luck and hope this helps
Apr 18, 2009 | Speed Queen AES28AWF Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
137 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
