Question about Alert Vehicle Parts & Accessories
1990 talbot express 2.5TD [swift kontiki] No flashers or hazard lights, intermittent problem. Where is the flasher unit and relay[s]
SOURCE: 2002 Workhorse chassis RV hazard flasher doesn't work
I am looking for a locking gas cap for my 2005 Bounder 36Z. This motorhome has a Workhorse chassis. Can you help me locate the part number and a dealer near Newberg, Oregon?
Thank you.
Sharon Bladow
503 554-1281
Posted on Aug 15, 2008
  • 1596 Answers
SOURCE: Bussmann Flasher for Saturn
The flashers are timed thru the hazzard switch. The hazzard switchneeds replaced. As for your other problems, has to be a body control module. The dealer will need to program this peice, as it holds the miles.
Posted on Jan 24, 2009
csmock132
  • 4669 Answers
SOURCE: Signals and Four Way Flasher working intermittently
Replace the hazard switch, It has the turn signal flasher built in to it.
Posted on Apr 09, 2009
bunnydawg
  • 5158 Answers
SOURCE: Indicators not flashing on Audi TT
i believe the audi uses two relays for the turn signals and hazzard lights so it would appear the turn relay has failed. it should be located under the dash near the steer column.... seems to me me they have some shielding under the dash so it may be hard to get to.
Posted on May 23, 2009
Molson02536
  • 3854 Answers
SOURCE: Constant clicking from flasher unit
The flasher unit has gone bad and needs to be changed. The flasher module is a part of the hazard module also. The clicking is the unit is still working but there is not enough voltage to activate the lights to flash. It's common on the Malibu's and other GM product cars similar to the Malibu like Grand Am's Ect. I believe Auto Zone has the replacement part for you car and is more reasonable in price then the dealer and the y also have the step by step instructions to replace the flasher module. Good luck and keep me posted, be glad to help.
Posted on Jun 03, 2009
Turn signals won't light up or flash
Test the arn?s on the light side. If you got juice there . Then replace the hole deal. If you dont get anyrhing. The is your turn anddle stick.
Jul 06, 2015 | 1990 Oldsmobile Cutlass Ciera
Silhouette 1990 where is the turn light flasher ,
you probably replaced the hazard flasher thinking it was the signal flasher as they look the same. look for the other flasher that you didn`t change.
Sep 12, 2014 | 1990 Oldsmobile Silhouette
Light flasher location
Its the relay for the flasher . Dose the hazard flashers work if so turn them on . Lisition for the clicking on a lots of chevys there is a relay center up under the dashboard under the raido its in the center some times vary tight to get to but with the clicking from the hazards you should to be able to find it. And by the way bolth relays the flasher and hazards are the same part so you can test by swooping them
Apr 22, 2012 | 1990 Geo Tracker
My turn signals won't come on at all?
check the fuse if good then turn on the hazard lights if they work then you probably need a turn signal flasher which is a separate flasher unit then the hazard one.it usually looks like the hazard one so with the hazards on and locate it then you will know what the signal flasher looks like and you will also know not to change the wrong flasher unit.the signal flasher is often located at or near the under dash fuse panel or somewhere in the dash you don`t say what type of car your talking about.
Dec 12, 2011 | Cars & Trucks
1990 buick lesabre turn signals don't work,hazard flashers work, bulbs are ok, running lights & brake lights work, just installed a new turn signal assembly, thought that would fix the problem, it did...
the turn signal flasher is a small canister-shaped or rectangular unit located under the dash, either in a clip adjacent to the steering column or in the convenience center which is located located under the right side of the dashboard and houses relays and other components. The fuse.faulty flasher unit a broken switch or a loose or open wire. We have eliminated the switch, I would check all fuses inside and out, you can replace the flasher with the hazard flasher as if I remember correctly they are the same shape and size, then it is just a matter with a tester light running it from the column to the sockets and finding the break. Hope this helps Tim
Oct 31, 2010 | 1990 Buick LeSabre
I have a 2001 chevy cav, and my turn signal are intermittent, the hazard lights work.. if its a relay switch were would be located?
Try the flasher unit inside the fuse box... I cant remember, but some cars have different unit for signals and hazard lights...
Jan 28, 2010 | 2001 Chevrolet Cavalier
Grand cherokee 2001 flashers dont work but hazards do...v odd??
The hazards and the flashers are on seperate circuits.When the flashers are working properly you will hear a clicking during operation.If not,check all the bulbs.If both flashers don't work it may be a blown fuse,faulty flasher unit or a loose wire or connection.Probably the flasher unit.Make sure the new one is the same as the old one by comparing the two,On yours,its a combination flasher and hazard unit.It will need to be replaced.its small and cost is minimal.When you do replace the unit,disconnect the neg. cable from the battery.The unit relay may be blue in color.Hope this helps
Sep 12, 2009 | 2001 Jeep Grand Cherokee
Apr 09, 2009 | 2003 Chevrolet Monte Carlo
Intermittent flashing on L or R turn or Hazard.
Hi Chalky!
I'm not familiar with your vehicle but if it were me I would put the Hazard Warning lights on and listen/feel the small relays/boxes close to the fuse board I'm sure you'll find it that way.
Good Luck!
Paul 'W'
Onyer~EDson(:0) {#><U.K.
Oh! please rate my effort.
Jan 21, 2009 | 1989 Suzuki Swift
Vehicle Parts & Accessories Logo
77 people viewed this question
Top Alert Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Alert Vehicle Part and Accessory Expert? Answer questions, earn points and help others
