Question about Kyocera Mita KM-2550 All-In-One Laser Printer
Ip address has changed due to a power outage, how do I reconfigure the ip address to my computer so they recognize each other?
SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
Posted on Jun 19, 2008
SOURCE: setting up wireless printer
To assign an IP address to a KM 3035 you need to select the system menu/counter button above the touch screen. On the left hand side of the menu you need to select Printer Defaults. From this menu you need to select Interface and than select the network tab from the resulting screen. Scroll down to highlight TCP/IP and select change. From this next screen you should be able to assign a new IP address.
Let me know if you need any further info.
Henry
Posted on Aug 15, 2008
SOURCE: oki3400n - how to assign a static ip address
I found this post via Google trying to solve the similar problem with C3200n.
>> this will then cause problems as all the pcs that are trying to print to this
>> printer will no longer be able to find the printer.
Originally, I also had this problem (with C200n, but it is probably similar). If I recall correctly, I solved it as follows:
1. Open the OKI LPR UTILITY from the machine you are trying to print from.
http://img8.imageshack.us/img8/4552/okilprutility2009080217.png
2. Choose Option > Setup
http://img8.imageshack.us/img8/9641/setup20090802171057.png
3. Make sure that the Auto Reconnect checkbox is checked.
Again, I believe that is what I did to solve that I couldn't print after power outages etc. The IP is not static, but it still solves the problem.
Static IP
Today I wanted a static IP for my OKI C3200n because sometimes there would be conflict between the IP for my printer and another machine in the house with a static IP.
What I did was the following.
1. In the printer menu locate the NETWORK MENU
http://img35.imageshack.us/img35/6889/dscn0525e.jpg
2. Go to the IP ADDRESS SET option, change from AUTO to MANUAL
http://img25.imageshack.us/img25/6122/dscn0526x.jpg
http://img195.imageshack.us/img195/7987/dscn0527j.jpg
3. Go to the IP ADDRESS OPTION, change to the desired ip address. In my case it was at 10.0.0.5, but I wanted 10.0.0.6 for the printer, so I changed it to that. Typically this is either 10.0.x.x or 192.168.x.x
http://img35.imageshack.us/img35/4407/dscn0528p.jpg
http://img90.imageshack.us/img90/1669/dscn0529r.jpg
4. Press the online button. The printer will reset the network connection (it took approx 1 minute)
http://img195.imageshack.us/img195/2539/dscn0530.jpg
5. This should be enough. You can try to ping the printer at the new IP, or navigate to the new IP in your browser:
http://img44.imageshack.us/img44/565/c3200nopera200908021755.png
Posted on Aug 02, 2009
  • 62 Answers
SOURCE: Scanner doesn't see PC in address book
is your scanner file utility program installed and running in the lower hand tasbar..in the file utility the scan folder number must match the one your entered into the machine
Posted on Jan 06, 2010
  • 10 Answers
SOURCE: I want to change the
try this one...used cd installer with network settings in your controller the installer im talking you about is the installer on your printer....
Posted on Oct 19, 2010
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
We recently changed high speed networks and our IP address changed. Since the change our zebra 2844 printers are not working. Is there a way to change the ip address for these printers? If so how.
Turn the printer off.
Disconnect the power-cord.
Reconnect the power-cord.
Turn the printer on.
It should automatically reconfigure itself, and get a "new" IP-address.
Then, you'll have to "delete" that "networked-printer" from your computer,
and then reinstall that "networked-printer", so that your computer can "talk"
to the printer at its "new" IP-address.
May 12, 2011 | Zebra Eltron TLP 2844 Thermal Label...
We have a wifi at home.. But every time a connect to it it doesn't work or connect either it always says "DISCONNECTED!"
Try using a static ip address and use the information from the router's ip address. (ip address, dns, subnet, gateway etc.)
Another option is to reconfigure your router by going to the router's ip address(which you can find [if on a computer] in control panel> networking>change adapter settings>local network>properties>ipv4 address)
Mar 26, 2011 | Samsung Star GT-S5233 Cell Phone
IP address of printer on the network has changed
You have to use the utility call SetIP that comes with the printer. Check the CDs. It is easy to use.
May 16, 2010 | Samsung ML-2851ND Laser Printer
We have 2 laptops going through this router and
First you need to verify that what kind of Internet connection you have from the satellite and what you need to do on the router so that it can communicate with the modem like MAC address cloning or changing the LAN IP Address. On the basis of that we will need to reconfigure the router back as it might happen due to a power outage or small network glitch the router might have lost the settings stored on it.
Mar 17, 2010 | D-Link DIR-300 Wireless Router
My network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
Mar 09, 2010 | Netopia (3347NWG-VGX) Wireless Router...
Need to change IP address for Actiontec router for verizon fios
definately you will need to change the IP address.
But you can also change the IP address of the wireless extender.
so instead of changing the IP address of the router, you can change the IP address of the extender.
For that you will need to connect the computer to the Extender.
assign a static IP to the computer 192.168.0.10 and Default gateway 192.168.0.30. that will open the set up page of the extender.
change the IP addres of the extender to 192.168.1.30.
that will help you.
For more info about networking click Here
Oct 21, 2009 | Actiontec Electronics (GT724WGR) Retail...
Need to renew ip address for my emachine T3516
just right click on your local connection on the desktop by the clock and click on "repair". this should clear the cache and renew the IP addy and DNS for yur connection. OR
Follow these steps to quickly release and/or renew the Internet Protocol (IP) address of a computer running Windows XP, Windows 2000, or Windows NT. Here's How:
  1. Click the Start menu button on the Windows taskbar.
  2. Click Run... on this menu.
  3. If the computer is holding a current IP address, type 'cmd' (without the quotes) in the text box that appears. A command prompt window appears on the screen.
  4. Type 'ipconfig' (without the quotes) to view the status of the computer's IP address(es).
  5. If the computer is holding a current IP address, type 'ipconfig /release' to let go of the address.
  6. Type 'ipconfig /renew' to obtain a new IP address (whether or not the computer is holding a current address).
Tips:
  1. If it is not necessary to view the current IP addresses on a computer, simply type 'ipconfig /release' or 'ipconfig /renew' (without the quotes) in the text box that appears in Step 3.
  2. To bring a computer back onto the network after moving it to a different location, or experiencing an unexpected outage, first release, then renew the IP address. Computers on DHCP networks often (but not always) re-establish network connectivity automatically
Oct 28, 2008 | Gateway Computers & Internet
The office has a new router for the internet, now the agents can't print from their own computers...How can I fix this problem
Is this a network printer?
If it is a network printer was it configured with a static IP or is it using DHCP?
Is the router also the DHCP server for the office? If so is it configured to the same subnet as the old router?
Network printer are often configured to use a static IP because a lot of routers do not support reserved IPs and if the IP of the printer changes, nobody can print. In this case, I am just about willing to bet that the IP of the printer stayed the same but all the computers changed. This can happen if your old router was configured (for example) with an IP address of 192.168.0.1 - it would assign addresses of 192.168.0.2, 192,168.0.3 etc to the computers on the network. If the new router has an IP of 192.168.1.1, then it would hand out addresses of 192.168.1.2, 192.168.1.3 etc to the computers.
192.168.0.x is a different network than 192.168.1.x (with a default subnet mask of 255.255.255.0)
This will cause a problem because the computers are on a different network from the printer (since its IP has not changed). The fastest and easiest way to fix this is to change the IP address of the router to be the same as the old router. Do not change the IP address of the printer unless you really feel like going around to all your computers and reconfiguring the printer ports.
Sep 27, 2008 | Office Equipment & Supplies
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
164 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
AAAA262430
Level 1 Expert
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
