Question about THQ The Lawnmower Man
Which way does the blade go on? Please - THQ The Lawnmower Man
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Should be in the manuel or type it into google etc.
Posted on May 09, 2010
How can i adjust the blade so it cuts thicker fur
Wahl KM-2 blades are not adjustable like the trimmers, what you need is a skip tooth blade or an 8.5 so the blade teeth are wider.
Please view
http://www.angliaclipperservices.com/Blades/Andis_Blades?product_id=166
Jan 15, 2014 | Wahl KM2 Professional 2-Speed Pet Clipper
Having difficulty with the blade tracking
Please read this blog : http://bandsawblog.com/band-saw-tracking-procedures/
I believe this will help you. Check if the blade is correctly installed and tensioned . Do you have
a good blade? It might be also blade issue. I got Haltbar blades of sawblade.com , no issue at all. Worn out tires can
also mess up the tracking. Please also check the coplanarity of the wheels.
Jan 17, 2013 | Saws
PLEASE PROVIDE INSTRUCTIONS FOR INSTALLING AND REMOVING BLADES CHEERS DENIS
There are two nuts up by the blade that will be removed to get blade off also there is a small screw next to the blade itself on the opposite side. You must loosen 2 big nuts then back this small screw off a few turns will be inside a small hole near blade. Once blade chain is loose take nuts off drop blade replace do everything now in reverse.
May 06, 2011 | Garden
What size are my wiper blades on my 1998 olds cutlass supreme
Hello tomkamy1: My name is Roger and I will answer your question. The passenger side takes a 19 inch wiper blade. The drivers side blade would be a 22 inch wiper blade. Should you need further help please just ask Please rate the answer. Thank You for using Fix Ya. Roger
Dec 18, 2010 | 1998 Oldsmobile Cutlass
Dewalt jigsaw (dw321) how to change the blade
UNPLUG TOOL. To remove the blade, lift the knob on the top of the jig saw approximately 1/4".
Rotate the knob counterclockwise until the clamp is open (Figure 8a). Do not force the knob once
it stops. Insert the blade as shown. Make sure the back edge of the blade fits into the support roller.
Tighten clamp by turning top knob clockwise until you hear a click. Push knob down.
For "T" shank blades, insert blade to the shoulder of the shank.
Look at manual on the link below.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf
Good luck please rate 4 thumbs up and please leave a testimonial
Oct 31, 2010 | Dewalt Saws
Planer no. kw715 spare blades black and decker please supply
The replacement blades for a Black and Decker KW715 portable planer are Black and Decker part number X24192. It looks like there are a number available on Ebay.co.uk at the moment.
There are also third party replacements for these blades. Trend PB/29 blades should work as well.
If this answer was useful, please vote for it. Thanks!
Jun 14, 2010 | Black & Decker Tools & Hardware - Others
Blade wont tighten
Here are some directions on installing the blade to ensure the proper procedure has been followed when installing.
  1. Set the blade orbit selector lever to position III.
  2. Fit the supplied screwdriver into the top plunger hole and loosen the internal blade securing screw about 3 to 4 turns counterclockwise.
  3. Insert the blade into blade plunger at a 90° angle to the cutting direction. With a slight upward pressure, turn the blade teeth forward (direction of cut) and guide the back of the blade into the groove in the center of blade roller guide.
  4. Pull gently down on the blade to seat the blade tabs in the plunger.
  5. With the blade in the proper position, securely tighten the blade screw by turning the screwdriver clockwise.
I hope this helps. Please rate on how helpful the answer was. Good Luck and have a great weekend.
Apr 03, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do I remove front wiper blades to replace with new ones on my 2006 nissan quest
How to Replace Wiper Blades Guide:
Potential tools needed to replace wiper blades:
  • Flat blade screwdriver (small)
  • Small nosed pliers
  • Latex or vinyl gloves
  • Safety goggles
To replace wiper blades the actual action of replacing the blade is no big deal, it's the location of the blade down below the hood that can make it difficult though. Sometimes it helps to open the hood to gain access to the wiper blades. Other times it is helpful if the wiper blade is somewhere in the motion line of wiper action. The trick is to get the wiper to stop somewhere in the wiper arc. Turn the wipers to the on position and allow the wipers to start, and then shut the key off when the wiper has arrived in a desirable position on the windshield. To replace your wiper blades please follow the step by step instruction below. Also, watch the How to replace wiper blades video below to gain additional information. The method in which the wiper blades are attached will vary slightly.
  • Step 1: With the hood closed, turn the wipers on, when the wipers are in the middle of their arc turn the key to the off position. (Note: if this can't be done because of wiper condition and you want to avoid scratching the windshield please open your hood to gain access)
  • Step 2: Locate the mounting clips at the top pivot on the wiper blade
  • Step 3: Release the clip and remove the wiper arm
  • Step 4: Match the size of the old blade against the new blade to ensure proper fit and operation
  • Step 5: Reinstall the new wiper blade and recheck wiper operation
Common Problems:
  • Make sure the wiper blades are the same size as the original blades.
  • When replacing wiper blades not getting the blade on the mounting pin completely allowing the wiper arm to become dislodged and possibly causing damage to the windshield.
  • Using wiper blades after the blade has failed permanently damaging the windshield by craving scratches in the wiper arc.
  • Wiper blade can create a chattering noise when the blade is not properly balanced allowing the blade to "flop" back and forth as the wiper direction changes.
I hope help you with this (remember rated this help) Good luck.
Sep 14, 2009 | 2006 Nissan Quest
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Blade replacement
the lever on the clippers locates into the cutter of the clipper blade its only a matter of lining the lever up with the slot in the top blade which you can slide from side to side by hand. Please keep in mind wear on this plastic Drive Lever may lead to cutting problems.
Apr 22, 2009 | Oster 76076-010 Hair Trimmer
THQ The Lawnmower Man Logo
170 people viewed this question
Top THQ Video Game Consoles & Games Experts
Jimmer_9
Level 1 Expert
James Wishart
Sandeep Kumar
Are you a THQ Video Game Console and Game Expert? Answer questions, earn points and help others
