Sony trinitron model 32S22
I CANT SEE THE PICTURE I CAN HEAR AND CHANGE BUT NO PICTURE
  • Anonymous Mar 26, 2008
    WE HAVE NO PICTURE OR SOUND ON THE TV
    Genius:
  • 1,139 Answers
Hello RENE1223,
This problem is related to the HV section of the TV or the picture . The fact that you have sound means that the power supply is working and this means that the HV section is partially working. You can not repair this yourself, because you will need to test points where the voltage can reach 40KV that is 40,000 volts. I would suggest that you take the TV to a qualified TV repair shop.
I hope this helps
Thank you,
Shuttle83
Posted on Mar 26, 2008
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
My sony trinitron kv-32v65 has no picture - standby light blinking - sound works through the bose sysytem, just no picture - help
if you cant repair a tv take it ot a w/shop and have it checked. let your tech check that an ht voltage of 95-105 is reaching a line transistor, also a transistor be checked for leaks, also let him check a line transformer, and the surrounding tin capacitors for leakages and change of values.
Mar 11, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Picture flashes off and on kv-32S22
Your local TV repair guy should be able to go in and recharge the picture tube. Just had mine done for about $165 and it looks good as new (and this was on a KV-32s22 that we picked up at a yard sale). Well worth it.
Feb 04, 2009 | Sony KV-32S22 32" TV
Screen went black and never ressurected
It is repairable.Open the TV and check the fuse and then the flyback transformer for any loose soldering. check for obvious burnt transisters, resistors, capacitors etc. the flyback is the component that has a wire to the picture screen on the inside of the TV. Be careful. Capacitors and picture tubes retain high current. If you don't know what your doing take it for repair.
Dec 29, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
HDTV signal
Does this model have a digital tuner built in it?
Jun 13, 2008 | Sony KV-32S22 32" TV
Horizontal line in the middle of the television
Hello RENE1223,
Normally this is not a costly repair. This is because it could be the vertical coupling capacitor. However if it is the yoke transformer it could get costly. There is no way for you to repair this problem if you do not have a background in electronics. So I would suggest taking the TV to a repair shop to get an estimate. If the estimate is within the range you are willing to spend let them fix it.
I hope this helps,
thank you,
Shuttle83
Mar 26, 2008 | Televison & Video
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Repair TV Sony KV32S22
The schematic diagram can be found here: http://www.eserviceinfo.com/equipment_mfg/Sony_2.html
Need to find winrar for the program to unzip the files.
Good Luck.
Feb 11, 2008 | Sony KV-32S22 32" TV
What`s seems to be the porblem
IT SOUNDS LIKE THE VERTICAL I.C. NEEDS SOLDERING. WHEN IT LOOSES THE PICTURE DOES IT HAVE ERROR CODE 2 ? THE RED LED BLINKING 2 THEN 2 THEN 2. THAT IS LOSS OF VERTICAL. IF YOU SMACK THE SIDE OF THE SET.(NOT TO HARD) WITH OPEN PALM ON LOWER BACK IF THE PICTURE COMES BACK IT IS THE VERTICAL IC THAT NEEDS TO BEE SOLDERED.
DON.
Jan 31, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
