Question about Mtd 22" Yard Machine Push Mower
Wont start then it dose but is very low and cuts out after a few seconds
  • 61 Answers
This would be a carberator problem. Clean, rebuild, or replace the carberator.
Posted on May 09, 2010
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
May 31, 2015 | Cars & Trucks
2011 polaris ranger cutting out
clean carb and all fuel delivery system lines
Mar 25, 2013 | Polaris 2011 Ranger 800 XP EPS
My car dose not want to start
the batt could still be low replace your battery if its that bad it probably has a dead cell good luck
Dec 25, 2011 | Nissan Cars & Trucks
My 2001 aurora was hit in the back and it cut-off now it wont start is there a fuel cut-off switch and if so where is it located.
Try disconnecting the battery for a few minutes, then reconnect. Or cycle the ignition off and on a few times on for 2 or 3 seconds off 2 or 3 seconds, three times.
Dec 27, 2010 | 2001 Oldsmobile Aurora
My mantis starts easily - but then dies. it sometimes doesn't even rotate. i can do about 3 seconds before it dies. help. what do i do?
The Carb is either cracked or needs to be rebuilt - OR - you might get luck and just blow it out with a professional dose of AIR from a larger compressor like used at mechanics shops.
Gary @ Fix Ya
Sep 05, 2010 | Mantis 2-Cycle Tiller
Engine cut out whilst driving along and it wont start now
check the vacuum hose from the inlet to the brake reservoir.......
Jun 07, 2010 | 2000 Alfa Romeo 145
2000 gmc jimmy wont start fuel pump comes on and cuts off but will not start.I have changed the fuel filter and that did not work. Is the pump not building the pressure it needs to start or would my...
the fuel pressure if leaking could cause this the regulator is located under the intake plenum but you should smell gas .if you dont then most likely the pump is bad ,the pump will come on for 2 seconds when the key is on then go off it will not stay on with just the key on only when you crank it will it .so have your fuel pressure checked with a gauge.
Mar 22, 2009 | 2000 GMC Jimmy
IDLING
HI
dose it start again?? dose it have acceleration in the first 20 second ??
if not . check the fuel pressure , fuel filter & fuel injectors
check and give us more details to help you again
with my best wishes
Jul 08, 2008 | 2000 Daewoo Lanos
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Mtd 22" Yard Machine Push Mower Logo
101 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
