Question about KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher
My dishwasher KUDK02CRBS4 will not turn on. The
My dishwasher KUDK02CRBS4 will not turn on. The plug has power to it. none of the electronics will work. It will not do anything? What can I do to fix this?
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
Hotpoint Built-In Dishwasher HDA3600DWWmy dish
there is an electronic solenoid near where the drainhose connects to the sump that changes the waterflow direction from recirculate(washing), to evacuate (draining). this is electronically controlled by the timer. you can test the power leads at the solenoid for voltage when it sould be draining. if none then the timer is faulty. if there is voltage then the solenoid is faulty. if the solenoid is engageing, then the water diverter is faulty. if the water diverter is broken, replace the dishwasher.
overflowing is another problem of its own. the water level float/ sensor is not working and could be caked with detergent. work the float from the inside of the dishwasher, it should move freely. if so, then there is a switch connected to the float on the underside. test it with an ohmmeter. if bad replace it. if it is an electronically timed water level control then it could be a problem with the timer as well, but with hotpoint they are usually manual.
Sep 27, 2013 | Hotpoint Dishwashers
This is not the exact model i have... but what do i do if my dishwasher will not turn on? none of the lights works or anything... but it is still connected... ive checked the direct plug and the breaker
if you have power to the unit then you will need to replace the main control board.but make sure to check the wiring and make sure everything is in good shape.
Nov 21, 2010 | KitchenAid 24 in. KUDI02CR Built-in...
My MAYTAG dishwasher Model MDB7600AWW buttons were giving trouble recently (not responding to touch). Now none of the lights or buttons seem to work (power is ok).
Hi!!
Unplug unit from wall outlet and wait a couple of minutes, plug unit back up and turn it on. This will reset the board and hopefully fix your problem.
Good Luck!!
Sep 21, 2010 | Maytag Dishwashers
None of the lights go on on the control panel. Dishwasher will not turn on. Wall plugs are in and the disposal plugged in to the same plug is working.what's going on?
Before you start pulling the machine to bits, just try plugging it into a different socket or an extension cord if there is not another socket close enough. (If it is currently plugged into to double socket don't just try it in the other one, make sure its a totally separate power point).
repost if problem still persists.
Jun 28, 2010 | Dishwashers
My dishwasher will not work..It's getting power but none of the lights or anything comes on..Is there a reset button on it or what can I do to fix it..
there are no reset buttons. if you have power to the panel or timer and still no operation then you need to replace the electronic control panel or timer
Mar 14, 2010 | Dishwashers
The dishwasher will not turn on
Congratulations - you found the fault !
The options you have are -
Buy areplacement board from a spares centre.
Buy a take- off board from a scrap one on Ebay.
Or - Learn about electronic repair - and identify the burnt component , buy the parts and replace it yourself.
You can take it to an electronic repair shop - if you can find one - or a electronic supply shop - and ask for a new one of "them".
If replacing a burnt component - often there is a cause other than just that component.
Experience tells you what else might be wrong to cause it.
Aug 04, 2009 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher will not turn on, power check done, please help
this looks like a power supply problem if you are sure you are getting power right up to appliance it can only be a electronic failure pcb open circuit etc anything else and the lights would still illuminate.
Jul 25, 2009 | Neff 24 in. S5444X1GB Built-in Dishwasher
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
"3 second" light flashing
Pard, does your serial number end with either WS or WU? If so, Maytag had a issue with the main board, triac shorting and possibley damaging the motor windings. If your serial numbers fall under this, you are probably covered under the service flash. Im not really sure what you mean by the 3 second button flashing. Check the numbers first and post back. Catriver.
Apr 21, 2007 | Maytag MDB7100AWB Dishwasher
KitchenAid 24 in. KUDP02CRBS Stainless Steel Built-in Dishwasher Logo
115 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
