Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
I need to know how to set the mowing height and do not have a manual
There is a red and black handle on the mower body on the right, squeeze it and move the entire mower case up or down and then let go of that handle to lock in new posotion
Posted on May 09, 2010
  • 623 Answers
Almost all mowers' cutting height is adjusted by little "tabs" at each wheel. The tabs need to be pushed in to adjust.
Posted on May 03, 2010
My 160 has started having trouble mowing at its normal speed in my yard. I have not changed the height I mow at, or the frequency at which I mow... What's happening?
i am assuming you are talking about a john deere. if it has a lot of hours or is very old the drive belt may need replaced if you are talking about speed. if you are talking about missing some grass the deck belt may need replaced.
Aug 20, 2017 | Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
2008 craftsman lt1000
you need a govenor adjustment take it in or or your waiting to long to mow grass slow down when you mow or mow more often
Sep 02, 2014 | Garden
Craftsman zts 7500 50" deck is there anyway to adjust height on this mower? at the highest level it cuts way to short and i have tons of grass blowing out the side cant hardly mow unless i mow about e
The range of the mover cut should be between 3-3/4" to 1-1/2".
If you are not getting these heights then the mover height mechanism may be jammed or broken. Use lubrication as instructed in the manual.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0803095.pdf
Sep 01, 2014 | Garden
Why does unit run sluggish when blades are engaged?
if you are talking about before even moving, it could be grass and dirt caked inside of the deck. If you are talking about when you start mowing, it could be front to back height adjustment. owners manual has instructions for adjusting deck height.
Jul 24, 2014 | Craftsman Garden
Uneven mowing
first make sure left and right sides are same height. Next, adjust front and back heights per users manual. If still off, make sure you dont have a bent blade or bent or missing front or rear deck link.
Sep 19, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to know how to properly set the guide wheel heights on the mower deck and the blade height for proper mowing heights.
with a marker,mark on the front of the deck where the blade height is, and do the same on the back, do this so you can get your measuring tap in there.play with the adjustments till you get the front and the back the same height,it should be around 5 inches florida up north 3-4 inches. it is hard to find a mower that can be set for 5''. the shorter you cut the grass the more watering it requires. check your grass type and search it's cut height and food requirements for you area or growing zone, for a happy healthy lawn.. jay the pump repair guy in longwood Florida
May 26, 2011 | John Deere 26HP Hydrostatic 54" Riding...
Mowing the lawn high and low
Mowing the lawn low and hi can only mean where are the adjusters or which is best.
The best height for grass is about 2 - inches for my nickle. There is no best - it is to your taste.
As for adjustments on your unit they are done with the handle that sets your deck height.
Let me know if after reading the instructions you still need help.
thanks
Gary @ Fix Ya
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
1989 Honda CB 1 carburetor float height
Hi, Bryndynw for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1989 Honda CB 1 carburetor float height Google Search
Need proper float height settings
1989 1990 Honda CB 1 CB400F NC27 Service Manual Moto Data Project
https://www.partsfish.com/page/oem-parts-for-honda
HONDA CB400F 1989 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 19, 2010 | 1989 Honda CB 1
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
144 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
