Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
My up flush toilet makes a humming sound every 5
My up flush toilet makes a humming sound every 5 minutes.... My doughter took a shower and had no pump sounds... flooded the bathroom...
  • 43,501 Answers
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
Posted on May 04, 2010
When I flush my macerating toilet the shower floods with the toilet waste. How can this be fixed.
you have a blockage in drain system. also make sure the air vent is ok.
Jan 18, 2012 | Saniflo Home
I have a saniflo and the shower doesnt drain straight away and when u flush the toilet it bubbles up the shower !
This sounds like a HOUSE plumbing issue. Is the line porperly vented? Bubbling sounds like the line needs venting. If you cannot go through the roof, they now make local vents that work.
Jul 11, 2011 | Home
I have a saniplus in a bathroom with a sink & shower. It isn't used often. The water backs up in the shower. The toilet won't flush, only hums. Any suggestions?
If the pump is humming and backing up then there is a blockage on the drain pipe, blades or the impeller. Also the capacitor may have gone bad and it will need to be replaced. The capacitor drives the blade and impeller, if it goes bad then it would just hum and not pump out the waste.
Oct 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniflo plus is making a humming noise but not draining any water away the sink has filled with water and so has the toilet and shower tray help
My saniflo-plus system is about 12 years old..recently it stopped draining the toilet, etc. I pulled the cover off the pump and checked for blockage and spun the cutter blades...The motor just hums....do I need to replace the entire encased pump assembly?? Help
Jul 07, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniplus motor (flushing noise) keeps repeating
I believe you have a problem with a leak. The pump is filling back up. See is the water is leaking out somewhere. Hopefully, you don't have a leak under the house. The water coming into the pump is going somewhere when it comes on.
Jan 28, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
877 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
