Question about Asrock K7VM2 Motherboard
The on board LAN network is not work, System
The on board LAN network is not working, System detecting on board network.
But keeps reporting that network cable is unplug when the cable is actually plug in.
I'm also experiencing another problem, one of the DDR channels is not working.
These problems arepresent on Windows xp, vist windows 7
How can i go about solving both of these problems
  • 11,800 Answers
1 - simple test: connect the pc to a switch using another piece of cable and look at the led on the switch corresponding to the cable - if it doesn't light up when you plug the cable in the pc then the onboard LAN is fried. Unrepairable, get a new PCI one.
2 - that board has a VIA KM 266 chipset that has only one channel of memory that can be either DDR266 or PC133 SDRAM.
Posted on May 03, 2010
Asus P8Z68-V Pro w/ I7/ 2600 LAN not working
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
hope this helps
Jul 08, 2012 | Computers & Internet
My device manager reports wireless adapter issue. I'm connected through LAN but my wireless networking is not working
Hi, try to uninstall the wireless adapter from the device manager and re-scan new hardware, it will pop up windows asking new hardware has been detected, if you have the driver in it, just seek the path where it is located and install the driver, let see what happen.
Jun 16, 2011 | HP Computers & Internet
Just installed a GA-PP67A-UD4-B3 mother board because the GA-P67A-UD4 board was dfective. I am running Windows 7, 64 bit. The new MB was a replacement provided by the manufacturer. Now, the Realtek...
Please enter into the BIOS settings and verify if under Integrated Peripherals the setting for Onboard H/W LAN is Enable. As additional step select SMART LAN and see if it will detect you cable lenght and Etehrnet speed. If Smart Lan do not detect anything or you have a bad onboard LAN or the cable, hub, router has a problem.
If SMART LAN will successfully report back some information it means that the issue must be with Windows 7. If it's the case i suggest to completely remove the network card, reboot and re-install the drivers.
Please let me know if you need additional help.
Mar 19, 2011 | Intel Motherboard
We have purchase several desktop PCs for the offfice use.. theres r lot of common issues.. 1.most of the time system gets corrupted in a sense, system get restarted over and over again without prompting...
NO OS stated why skip that? XP,? SURE ITS CORRUPTED ALL ARE NOW. and will get works, dead now for 3 years at MS.
the coin cell battery is dead if time clock fails.
for sure the clock in BIOS screens !!!
the NIC chip, or the Ethernet chip can be on board
or an actual NIC, nic means network interface card.
SR2150NX (HP retired this for support)official.
10 years old at least.
some came with VISTA is it VISTA, be nice to say.
does have this old slow chip
Integrated 10/100 Base-T networking interface
on board, or has addin board, open case look?
see what board added,? like giglan card?
the HP site clearly shows this chip
Realtek RTL8100
the driver can be had at realtek
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false#1
I run a system PCI sniffer to get all chip true names,
no screw driver need no mag lens to read chip tops.
or here
http://driverpacks.net/driverpacks/windows/xp/x86/lan
27million drivers now, happy hunting.
3 ways to get them here. (HP, chip maker, or way3 seen here)
http://www.pcdied.com/Drivers.html
the first chip to get working with PC that runs
is what RTL8100, but you cant because its dead LAN.
so only at a PC connected to the web can you get it
and move it to dead pc. dead LAN.
(called sneaker net in the old days) sneaking PC to PC.
Aug 30, 2017 | HP Compaq Presario SR2150NX PC Desktop
I have failed to install ethernet driver after
your operating system should detect and install the drivers for your network controller if it is an internal on board LAN. however you must be sure that you have the LAN enabled in your BIOS setup under the advanced selection on the bios screen. otherwise , your operating system won't even see that you have a LAN connection.
Mar 01, 2010 | HP Compaq d530 SFF PC Desktop
Need to find a lan driver to foxconn CO2
There are three options you can do,
(1) run your disc that came with your computer,it should be your windows xp disc or your vista disc also try using the system recovery disk,this should work,if not you can go to HP Compaq presario website and type in the product number which is SR5410F, in the search box type foxconn CO2 lan1_usb12, follow the directions as you can download it from their website.
Jan 20, 2010 | HP COMPAQ Presario SR5410F Pentium...
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
Acer Aspire 3620 wireless lan keeps shutting down my system.
This issue arise when there is conflict between drivers the best we can do is to open device manager click on Vien and then select show hidden deivces and disable every driver except your wireless adapter and see if it works.
Thank you please revert back for any clarification.
Nov 18, 2008 | Computers & Internet
Lan Network Problems
Hello: What I would say is: go to microsoft update and make sure you have all the updates for your OS.
Then; read the posting (below) from someone who had the same issue:
stacemarie wrote: "XP SP 3 updates some networking sharing system LAN files that cause some configurations to become unaccessable on the workgrouped networks. We cannot - even ping - the network addresses after installing - so it was an uninstall and do a system restore to get to the original good working state of the clients.
Microsoft needs to come up with a patch to fix this as we are seeing more and more networked clients having these connection and sharing problems."
Do you understand the above?
Let me know if you do not know how to unistall SP3 and do a Restore...
Jun 24, 2008 | LanReady LA1000+ Network Adapter
Wireless LAN problem
Make sure that the built-in wireless lan is disabled. If your pc is XP or vista, uninstall the new WIRELESS LAN(go to control panet, add/remove programs), select the Atheros Software. Leave the WIRELESS ADAPTER connected to your pc. Insert the disc, do not run the set up. RESTART THE PC. The drivers for the WIRELESS ADAPTER should install, if not load drivers manually.
MAKE SURE WIRELESS ZERO CONFIGURATION for XP is running. You should be able to detect wireless networks.
Mar 15, 2008 | Computers & Internet
Asrock K7VM2 Motherboard Logo
118 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
