Question about Saeco Royal Coffee Bar Coffee Maker, Espresso Machine
Have descaling message and plumbed for water how
Have descaling message and plumbed for water how do I program to descal
  • 1 more comment
  • Andy Weber May 03, 2010
    I have a Royal Coffee bar and it has given me a message to descale the machine--- this is a periodic message based on useage. I am looking for the programing steps to
    1 descale the machine
    2 flush
    3 return to normal operation resteing brewing counter
    This does not answer my question as to program and desacel my machine
    How do I program the machine thru the steps of
    Descaling
    Machine is Desaling
    Descaling Finished
    Rinse Machine
    Rinsing Finshed
    Reset Desacling Message
    Is there a way I can get my money back Your suggestion is not correct
  • 713 Answers
Hi,please begin the Descaling Process by following the instructions below:
1.Fill your Cup or Pitcher with Hot Water, you can use hot water from the Espresso
Machine Steam Wand - this is the perfect temperature to dissolve your Saeco
DezCal mixture. If you are not sure how to select hot water from your machine,
see your manual or download your manual on our website. Usually, your espresso
machine will have a Hot Water Button that looks like a teardrop, pressing this
button if so equipped, will select hot water. Allow 6 OZ water to flow through the
wand into the cup.
2.Dissolve one packet of Saeco DezCal in your cup. Make sure
that all of the small crystals have been dissolved into the hot water.
3.REMOVE any Installed Water Filter.
4.Fill your water tank about 3/4 of the way full of cold water. Pour in the dissolved
mixture from Step 2, completely into the water tank.
5.If your machine has a descaling cycle, enter the menu on the machine and begin
the descaling process. Digital Machines have the Menu Item, non-digital machines do not have this cycle. If you have a non-digital machine, open the steam wand up for HOT WATER not steam and allow 4 OZ to flow through the wand, shut the
wand off, wait ten seconds, then repeat this process of WAND ON - FLOW 4 OZ -
WAND OFF; once the entire water tank has been drained of the descaling mixture,
6.Rinse the water tank with cold water and fill to the top with cold water. Allow at
least 32 OZ of cold water to flow through your steam wand immediately, without
pausing.
7.Fill water tank again with cold water and proceed to step 8.
8.If you have a Descaling light or Indication that needs to be reset, then reset your machine.
Thanks and take care
Posted on May 03, 2010
    President:
  • 1,469 Answers
Hello, Preventive descaling (Water treatment and preventive descaling) DESCALING SOLUTION Generally, a flush through descaler uses about .5 to .75 fluid ounces (1 to 1.5 tablespoons, or 8 to 12 grams) of citric or tartaric (grape) acid powder dissolved in 1 liter of water. This is a 2.25% to 3.5% solution, equivalent to 33% to 50% dilute lemon juice. Cleancaf and other coffee manufacturers' descalers use this formula. Theoretically, these amounts will dissolve about 12 to 18 grams of scale per liter, but that would require leaving the solution in for several days; in practice, it is used for an hour or two to dissolve up to 5 grams of scale. The formula is mild enough to be harmless to espresso machine components, but it will come out of brass or copper machines with a slight greenish tinge. This comes from milligram levels of dissolved copper and is no cause for alarm. 5 lb bags of citric or tartaric acid cost about $10 at home brewers' or soapmakers' supply stores. This is roughly a 20 year supply DESCALING INTERVALS Know the hardness of the water you're using, and how much you use the machine. Descale when accumulations are between 2.5 and 5 grams. More often is a waste of time, less often may result in scale build up. Check out section 1.7 for instructions on determining your set up's scaling rate. SINGLE BOILER MACHINES For single boiler machines, preventive descaling is no problem, just follow the instructions given by the manufacturer. In general, this involves filling the boiler, letting the solution work for about ten minutes, and replacing it by running it out of the steam wand under pump pressure. This procedure is repeated three to five times, until about a liter of descaler is used up. Then the machine is flushed with water until any taste is gone. Manufacturer's recommendations differ on whether the brewhead should be flushed or not. This is not surprising. The water's temperature drops and LI rises as it moves from the boiler to the head, so scale won't form there. In scaled machines however, fragments can move from the boiler into the head, fouling the gicleur valve. My guess is that with regular descaling, flushing the head is unnecessary but harmless. I do not know if the dual boiler Techno can be descaled in this way, or if there is some procedure peculiar to it. HEAT EXCHANGERS HX machines have two things to descale, the boiler and the heat exchanger(s). Any descaling of a plumbed in machine will involve moving the water inlet pipe to a tank that can hold the solution. Doing the heat exchanger is as easy as a single boiler machine. Just run descaler through it until it exits the brewhead (or HXed tap). Leave the descaler in for 5 to 10 minutes with the machine off (or 2 to 4 with it on), then run out a 3/4 cup worth, repeat six times until you've used up a liter of descaler. If the boiler refill comes on during this period, very little harm is done, since it will be adding only 20 ml or so to a liter or more of boiler water. Boiler flushes (see below) can be scheduled after an HX descaling to minimize this problem even further. However, ONLY USE CITRIC OR TARTARIC ACID FOR HX MACHINE DESCALING, since if any remains in the boiler it's no big deal, whereas smelly vinegar or cleancaf's detergent could be a problem even at low concentrations. HX MACHINE BOILERS Descaling the boiler is much more of a headache. If you cook, you know that scale preferentially forms at the waterline. This means that filling the boiler with descaling solution only to the autofill line is not going to be very effective, since the descaler will barely be in contact with the bulk of the scale. Disconnecting the autofill (a wand like device sticking out of the top of the boiler with a single wire attached) will fill the boiler to a higher level and allow the descaler to work on this "rim". In machines with a direct boiler tap, the boiler can be filled by opening the water tap, and letting the autofill refill the boiler with descaler. When that's done, close the tap, and disconnect the autofill for 30 seconds or so to fill the boiler a little above the regular water line. On machines without a direct boiler tap, the autofill has to be disconnected, and the fill may have to proceed by flushing the boiler through the steam wand. If there's an easily accessible drain, it may be easier to use it in conjunction with the autofill. If you're draining via the steam wand, don't let the machine get too cold, otherwise the vacuum breaker will leak. Disconnecting the autofill at the sensor risks shifting the sensor's depth, so it's best to buy a spade lug and its mate, or an inline switch that is rated for 130C ambient, and use them to make a disconnect in the wire to the sensor. One can even extend the wiring so this can be done without removing the case (i.e. so it's reachable at the water tank). Once the boiler is filled with descaler, leave it in for two and half hours with the machine off, or one hour with the machine on. The descaler is flushed out using the same procedure that brought it in, either via the tap, steamwand or drain. Keep flushing and refilling until there's no more lemon taste. This may take about twice as much water as is usually in the boiler. It's best to refill the boiler with RO water (see below). Add 5% to 10% tap water to keep the autofill happy. Take care.
  • Egwe Emmanuel Onyedikachi
    Simply press the coffee brew button and let the machine do the rest.
    Gone are the days of having to grind your own coffee, tamp it, brew it,
    and clean the mess after you are finished. Thanks to the hands free
    brewing system, all you have to do is press a button to get your coffee.
    The Royal Coffee Bar grinds, tamps, brews and cleans...in less than 30
    seconds!
    Take care.
    descaling a coffee bar coffee maker can not be programmed, But can be done manually.
    You can use this link to do that
    buzzle.com/editorials/5-7-2006-95447.asp .
    That is the nly way you can do it.
    Take care.
How do you descale if the water won't go into the unit???
Is this a plumbed in machine Donna? Normally there is a tank at the back for descaler and a tap to switch water intake from plumbed to tank.
Refer to manufacturers instructions.
Google
make model descale
Nov 11, 2016 | Coffee Makers & Espresso Machines
Tip
Proper way to descale an espresso machine.
Hi
I have seen all ways to descale espresso machines on this and other sites and most are wrong!
Never leave the machine heating while the descaler is in the boiler. It's OK for a few seconds but never for minutes or hours. It will turn your seals hard as a rock and the machine will start leaking. If your machine is leaking you probably left your machine on while it was descaling. Factory programs, if used do not turn the boilers on in the descale mode for this very reason.
If your machine has a factory descale mode, use it. All factory descaling programs use the flow meter to regulate the descaling. The flow meter tells the computer how much water has gone through the boiler. when the machine is out of water the flow meter will stop turning and the computer knows the machine has used up all the descaler, and it will want to be rinsed. Remember the pump has to stop on its own for the computer to know it's done! Again the flow meter will tell the computer it is rinsing and when it is again out of fresh water it will tell the computer it is done rinsing and the descaling message or light will disappear. Remember the pump has to stop on its own for the computer to know it's done! It may say descale on some computers and there is a program for resetting the descale. It's in your menu as "Reset Descale". Choose "Yes" and push the menu button to lock. It's all regulated by your water hardness. I have mine set on 4 and my water is very good. I have over 20,000 drinks, and the original boiler. Saeco(Starbucks) Barista Digital.
This method can be used on any espresso machine.
1. Remove the water tank and fill half way with fresh water.
2. Mix your descaling powder (Citric Acid or Durgol Never use Vinegar) in a glass of warm water. When dissolved pour into water tank.
3. Open steam knob. Have a large bowl under the wand to catch the water expelled from wand.
4. Turn on machine (automatics will cycle then start pumping water) Regular espresso machines you will need to turn on the brew button.
5. When the pump has expelled about 8 ozs through the steam wand turn off only the power button. Leave the other buttons and knobs alone.
6. Wait about 10 to 15 minutes for the descaler to work, then turn the power button on and run another 8 ozs through the wand and turn off the power button.
7. Repeat step 6 until the water tank is empty. (machines that have magnets in the water tank will not let you pump the water tank dry but they have programs built in to use that will)
8. Once the tank of descaler is empty, rinse out and fill with fresh water.
9. Open steam knob and run the complete tank of fresh water through the boiler without stopping, and once its complete refill with fresh water and your ready to go.
on Jun 03, 2011 | Saeco Vienna De Luxe Espresso Machine
Descale
Delonghi EAM, ESAM, ECAM, Nespresso
Over time, the continuous heating up of the water used to make the coffee leads to lime scale building up in
the inner circuits of the appliance.
When the appliance displays the message:
DESCALE
you should perform the descale cycle.
Proceed as follows:
• make sure the appliance is ready.
• press the button (the light over the button comes on) then press the button repeatedly until
the appliance displays:
DESCALE No
• Press and the appliance displays the message:
DESCALE Yes
• Press the button to start the descale programme.
• Empty the water tank and add the contents of one bottle (125 ml) of DURGOL descaler plus
one litre of water. For subsequent descaling, use descaler of the same type and brand as supplied
(available from technical service centres authorised by the manufacturer).
• attach the water spout to the nozzle;
• place a container with a minimum capacity of 1.5 litres under the hot water spout (Fig. 3);
• press the button. Descaler runs off from the hot water spout into the container below. The appliance
displays:
APPLIANCE IN DESCALE
• the descale programme automatically performs a series of run offs and pauses to remove lime scale
deposits from inside the coffee maker.
• After about 30 minutes, the appliance displays:
RINSING FILL TANK
The appliance must now be rinsed through to eliminate residues of descaling solution from inside the appliance.
Proceed as follows:
• empty the water tank, rinse and fill with clean water.
• Reposition the tank.
• Empty the full container and then put it back under the hot water spout.
• Press the OK button. Hot water is run off from the spout into the container below and the appliance displays:
RINSING
• When the water tank is empty, the appliance displays the message:
RISRINSING COMPLETE PRESS OK
• Press the OK button and refill the water tank with clean water.
• The descale programme is now terminated and the appliance is ready to make coffee again.
NOTE: if the descaling cycle is interrupted before completion, the appliance continues to display the descale
message and the programme must be started again from the beginning. Empty the water tank, rinse, fill with
clean water and run off a cup of hot water.
IMPORTANT: FAILURE TO DESCALE THE APPLIANCE REGULARLY INVALIDATES THE GUARANTEE.
Nov 25, 2011 | DeLonghi Magnifica 3300 Espresso Machine
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
The machine says to descale _ How do I do that???!!
THIS INSTRUCTIONS ARE FOR THE MIELE CVA 615,
The coffee system must be descaled regularly. The time period depends on
the water hardness set. The appliance will display a reminder message and
will eventually lock if not descaled. The message window will first display:
"DESCALE AFTER COFFEES: 100".
This message will appear until the appliance is descaled or locks. When
the count is down to zero, the appliance will lock and the message
window displays: The appliance can only be used again
once descaling has been performed. Let the machine cool before
descaling. Remove the sleeve of the steam nozzle to avoid damage from
the descaling agent. Only use the enclosed descaling tablets for descaling.
The descaling tablets are specially designed for descaling this coffee
system. Other agents may damage the machine and affect the taste of
the coffee and hot water. The descaling tablets can be purchased
from Miele.
To prevent damage to the exterior of the machine wipe up any descaling
solution spills immediately! Add 2 liters of water to the water tank. Dissolve two of the enclosed
descaling tablets in the water.
^ Close the water tank and insert into position.
^ Close the door. The descaling will take place in the
automatic descaling program.
Automatic descaling
^ Turn the program selector
counterclockwise to the "Program
mode" position.Press e, to select "Descaling" with the asterisk. Press ENTER.
Jan 17, 2011 | Miele Coffee Makers & Espresso Machines
I need to decalcify my delonghi 4500
Descaling is another word for decalcification - I would consult the user manual for your exact model, because these directions are actually for the EAM3400, so there might be minor variations:
DESCALE
You should perform the descale cycle.
Proceed as follows:
DESCALE NO
DESCALE YES
• Press the button to start the descale program.
• Empty the tank and pour in the contents of one bottle (4.2 fl. oz.) of DURGOL descaler plus 34 oz. of
water. For subsequent descaling operations, descaling solution can be purchased from authorized technical
service centers.
Note: Make sure splashes of descaler do not fall onto surfaces sensitive to acid such as marble, limestone
and glaze.
• Place a plastic or glass container with a minimum capacity of 50 oz under the hot water spout (Fig. 3);
• Turn the steam knob half a turn counterclockwise (fig.3). The descaling solution will run out of the cappuccino
frother and start to fill the container underneath.
• The descale program automatically performs a series of run offs and pauses to remove lime scale deposits
DESCALING COMPLETED TURN KNOB
• Turn the steam knob a half turn clockwise as far as it will go (fig. 4).
Proceed as follows:
• Remove the water tank, rinse and fill with clean water.
• Empty the collection container (under the cappuccino frother) full of liquid and then put it back under the
cappuccino frother.
• Turn the steam knob a half turn counterclockwise (fig. 3).
18
Hot water is run off from the cappuccino frother into the container below and the appliance displays:
RINSING
RINSING COMPLETED TURN KNOB
• Turn the steam knob clockwise as far as it will go (fig. 4) and refill the water tank with clean water.
• The descale program is now complete and the appliance is ready to make coffee again.
message and the program must be started again from the beginning.
Mar 22, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Bosch tassimo
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Delonghi EAM 6600
You need to descale the machine with descaling solution.
look at following link for instructions
DELONGHI
May 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Royal Coffee Bar Coffee Maker, Espresso Machine Logo
108 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
