Question about Kenmore 63942 Dryer
My Kenmore elite dryer quit blowing hot air, what should I check first?
    Genius:
  • 1,122 Answers
Remove the bottom panel and check the fuse and the heating element ,the fuse is on the left side of heter box near the back and the element is in the heater box
Posted on May 03, 2010
My Kenmore Elite Smartheat QuietPak9 dryer quite blowing hot air.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 06, 2011 | Kenmore Dryers
It takes several cycles to dry clothers in my Kenmore elite He4 dryer, it feels like hot air is blowing but the clothes are not getting dry any suggestions?
werw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. or you have a defective heat coil
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite gas dryer 110.74956300 gets warm but not hot. Air vent is clear.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 22, 2010 | Kenmore Elite HE4 Electric Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Dec 16, 2009 | Kenmore Elite HE4 Electric Dryer
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Dryer will run for a second and sound three beeps and stops.
Sounds like the door switch has gone bad., but your description is confusing.
First, it takes a few minutes for you to feel the air blowing hot, particularly when the dryer is in a cold garage. The heating elements have to heat up the mass of the metal, and any clothes in the dryer.
The timer design is such that it can not speed up (the motor inside wont start running faster, due to it's electrical design.).
I am suspect that the door switch has failed for some reason, because reading between the lines, I think you are saying when you release the Start button, the dryer quits operating. If the door switch is bad, then it will cause that condition to happen.
Jan 18, 2009 | Kenmore 62802 Electric Dryer
No heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Sep 22, 2008 | Kenmore 64982 Electric Dryer
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 63942 Dryer Logo
113 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
