Pc starts then switchers off strait a way - Computers & Internet
  • 22 Answers
You most likely have a loose heatsink which is component that dispenses heat of the processor. This can be fixed by tighting the screws on the heatsink.
Another fault could be a bad heatsink or a bad cooling fan.
Posted on May 03, 2010
Anti theft system -can't start car
there is some issue with ur anti theft sy.
Jun 15, 2008 | 1997 Volkswagen Jetta
Tip
Kramer VS4x4ycyl Manual Download
Download Kramer VS4x4ycyl Video Audio Matrix Switcher Manual
Have you misplaced your Kramer VS4x4ycyl Video Audio Matrix Switcher Owners Manual?
Would you like a digital, searchable, pdf version of the VS4x4ycyl Video Audio Matrix Switcher User Guide?
Follow this link (& click FREE) to download a pdf version of the VS4x4ycyl Video Audio Matrix Switcher installation instructions.
I hope that helps.
_______________________________________________
on May 09, 2010 | Audio Players & Recorders
How to uninstall non responding applications on pc
1 go to start and wright in the searchbox msconfig than enter
2 in the box you find the section with start
there you find the ip switcher and unsigne it from the start list.
3 get the iobit uninstaller and remove the ip switcher.
Sep 18, 2013 | Chris Knox IP Switcher Widget
Pink and green colours seem to be too vibrant when watching dvd's on lifestyle 48
I have a Lifestyle 48 which suddenly started producing a pink and green image when playing DVDs (regular TV was fine.) After speaking with Bose support, I did the following which resolved the problem:
1. Removed power from the video switcher. (or from the bose itself if you don't use the switcher.)
2. Reattach all the video cables on the back of the bose and ensure all connections to the TV and switcher (if applicable) are tight.
After performing these steps, my DVD image went back to normal. I suspect it was a loose cable in the end, but no harm in performing the power disconnect.
Apr 11, 2010 | Bose Lifestyle 35 System
Audi switcher : out
HI,
1.click Start -> Run … enter:services.msc
2. Click OK, a services window will appear, scroll to windows Audio, double click
3. Windows Audio Properties will appear. Change startup type to “Automatic
4. First click Apply, then click on start to start the service
Does it solve your issue?
Aug 27, 2009 | Computers & Internet
Trying to connect two PC's to a Netgear FE108 switcher and a Thompson cable modem. Modem is connected to "Uplink" port on switcher. Normal/Uplink switch on switcher is set to "Uplink" Can connect one PC if...
Any network device, PC or otherwise, needs an IP address assigned. So, yes, both your PC's need an IP address.
Assuming your ISP lets you have multiple PC's(IP's) then you'll have to use the IP space provided by your ISP. The default gateway would also be provided by your ISP.
The way you SHOULD do this is to use a router, linksys for example. This way you can setup you private network(I.E. 192.168.10.10 for example). This will hide and protect YOUR private space from would be hackers. The router would use the REAL IP address on the outbound side to talk to the cable/DSL modem.
btw...you can use the ipconfig command at the command prompt(I.E. a DOS window) on your working machine to see the DHCP address and gateway that was assigned. Sound like your ISP only allows you one IP. The router solution above will fix that and let you connect as many as you want because the ISP will only see the one IP from the router.
Dec 07, 2008 | NetGear FE108 8-Port Ethernet Hub...
Connecting Wii through Component cables and Phillips switcher
I just did some more checking...
When you have the Wii connected to the AV Switch, try turning on the DVD player too, but have the switch set to show the Wii on the TV. It is odd, but that has worked for me.
Jun 19, 2008 | Nintendo Wii Console
Contacts button and Start menu item not responding
Since "Contacts" on the start menu fails at the same time as the button, it is more like that there is a software problem, and the button cannot open the applet that is failing. If you want to ensure that you do not have a hardware problem, try remapping the button to open another application. You can do this by going to Settings/Buttons. You might want to try using the Task Switcher, which you can turn on in Settings/System. When you encounter the problem with Contacts, then click on the Task Switcher and see how many programs are open. Use the Taks Switcher to close all the programs, and then try Contacts again and see if it works. Most applications do not close, and if you have many open applications, then it will degrade performance.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
