Question about GPS
I enter an adress and my garmin 1340 gives the not found message but the adress is on a conventional printed map. I do have sattelite recognition and I live in the south of France.
    President:
  • 1,851 Answers
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
Posted on May 08, 2010
Testimonial: "Thanks for your help, very useful, problem now solved."
My Garmin nuvi 200 says no detailed maps found where can I download a map
You may not need to download a map. It's possible that the map is there but not selected or that it's locked. I'll give you details first of how to solve this problem and then I'll give you details of how to get a new map. Your satnav must be registered with garmin to unlock the map or to download new maps. If it's not already registered you can register it at https://my.garmin.com/mygarmin/customers/myGarminHome.faces Click Register Your Garmin Product and follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them again anytime you want to update your satnav.
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
To update the maps Log into my Garmin. Click on myMaps. If there's an update it will be shown there. Click on Get Update and follow the prompts. Maps are large Europe is approx 4Gb so you'll need broadband to download it. If you don't have broadband you can opt to get the update posted to you on DVD. You'll also need a credit card to pay for it.
Aug 08, 2010 | Garmin nuvi 200W GPS Receiver
The Garmin 1340 works fine, but dont works in my pc!!
download and install the software driver from Garmin.com
Jul 29, 2010 | Garmin GPS
Just updated the software with webupdate for windows_242 from garmin website succesfully. ''No detailed maps found that support routing. The street pilot cannot be used without them. comes up when...
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
To check that the map has not been disabled. Press Tools, then press Settings, then press Map, then press Map Info and see if your map has a tick to show it's selected. If not press the map name to select it. It should then work.
Jul 27, 2010 | Garmin GPS
Garmin nuvi750 not taking new adress if i try to cange stae or city it says ''no match found''
You map may of been turned off. If so. Go into your Tools menu. Then Settings. Then Map. Then Choose Map Info. Make sure that there is a check mark beside the map name. If there is no map listed you should contact Garmin for assistance. www.garmin.com
Jul 14, 2010 | Garmin nuvi 750 GPS Receiver
Says no adresses of maps found, what does that
Periodically, the firmware or 'brains' inside phones, mp3 players and GPS devices get confused. They begin to work erratically, or refuse to complete their startup routine at all. The good news is that 99% of the time, new life can be breathed into them by either a reset procedure or a firmware / system software replacement.
Here are the steps to fix your Garmin Nuvi 205W:
  1. If your Garmin NUVI 205 can be recognized by your computer when plugged in, I recommend you backup your favorites.
  2. Then I suggest a hard reset.
  3. Finally, replace the firmware and system software using webupdate.
I hope that helps.
Apr 12, 2010 | Garmin nuvi 205W GPS Receiver
SATTELITE NAVIGATION
Install Mapsource program from the CD and also install the maps. Start Mapsource program and use the Map tool to select the states you want to install. Now hookup your Garmin to the computer and Transfer the maps to the Garmin
Oct 19, 2007 | Garmin StreetPilot i3 GPS Receiver
Map fro Garmin
As far as I know you can only buy maps from Garmin, or a Garmin retailer.  The 660 should have all the maps for North America already loaded in it.
You can purchase Points of Interest (POI) databases from a variety of sources.  Just google POI.  These are not maps but they are adresses for points of interest such as restaurants, special services, and even speed trap cameras.
Oct 13, 2007 | Garmin Nuvi 660 GPS Receiver
Adresses
Well mine did the same thing. It was a simple fix, just go to the wrench -> map -> map info -> and make sure the box by your maps is checked.
Sep 03, 2007 | Garmin Nuvi 660 GPS Receiver
GPS Logo
56 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
