Question about RCA JET S2002 MP3 Player
Can"t turn it off.
How do you turn off the jet?
    Problem Solver:
  • 6 Answers
Does it hang?
If it does, find the reset button. Any batteries? If there is, remove it and put it back again. Or press the start button for 10 seconds. (typically)
Posted on May 03, 2010
Every time I put the heater on the jets turn on wont go off unless I turn the heater off.
some more infromation would be great, but the jets turn on to run water through the heater to heat the water, do the jets turn off once the water has heated to the thermostate set point.
Dec 20, 2014 | Intex Pool & Spa
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
Xl250 r 1987 where is the pilot jet located
Remove carburettor bowl and the pilot jet is just forward of the main jet and emulsion tube. If pilot jet is blocked either carb clean or strand of electrical wire will clear it then blow out with compressed air. Fuel mixture screw is just forward of float bowl. Start at 1& half turns out from seated.
Nov 29, 2013 | Motorcycles
Factory Jet Sizes
Front cylinder carburetor:
112.5 Main Jet
17.5 Pilot Jet
(1) 0.020" thick shim washer under the needle
PMS setting apparently varies from bike to bike... but it should be 2.5 turns
Rear cylinder carburetor:
110 Main Jet
17.5 Pilot Jet
May 23, 2013 | 2000 Yamaha V Star 1100 Classic
How do you adjust the high speed, low speed jets on a 2002 Yamaha Road Star carburator.
The jets are not adjustable. Well - the pilot jet is adjustable a little by turning the air screw, but this is for fine tuning, not for correcting an incorrectly sized jet. If the air screw is screwed out more than about 2.5 turns, the pilot jet is too large and if it is turned in less than 1 turn, your pilot jets are too small.
Adjust the air screw out until you get the highest, smooth idle and then turn back in about 1/4 turn or less.
It is a good idea to check or just change your air filter prior to making any mixture or carb adjustments - make sure the intake tract is not restricted and make sure the spark plugs are in decent shape.
To 'adjust' the jets, they must be replaced. I know this is not what you were hoping to hear, but to adjust the jetting, the carbs have to come off and you have to get into the float bowls to physically change the jets.
Sep 14, 2011 | 2002 Yamaha Road Star Silverado
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Aug 16, 2011 | Home
CHAINSAW HAS BEEN SITTING UP REPLACED PRIMERBULB AND FUEL LINES. HOW DO YA SET CARB.
You have to adjust the jets at 1.25 turns out.This means turn jet in until it stops.Do not force or you will damage the jet.Then turn out 1.25 turn on both jets.Then you can fine tune from there.
Nov 15, 2010 | Poulan 18" Chain Saw Replbar (small Saws)
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Some jets dont work
jets don't 'clog' - turn the face of the jet nozzle - it is perhaps an adjustable jet you have that has been turned off.
Apr 18, 2009 | Home
Bathtub jacuzzi (motor turns runs but nothing coming from jets)
Each Jet will have an adjustment many times right on the jet nozzle. Carefully try to rotate them counter clockwise to open up the jet. This assumes you can here the motor running.
Phil
Nov 21, 2008 | Home
Open Questions:
RCA JET S2002 MP3 Player Logo
219 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
