Question about Rowenta DG-980 Iron
Low steam due to clogged vents - Rowenta DG-980 Iron
    Scholar:
  • 70 Answers
Only clean your Rowanta 980 with clear filtered water only. The unit comes with a small hose and faucet adapter to flush the steam tank thru the threaded plug when cold. Do not use hard tap water, that is where most of the mineral deposits come from. The other is storing the iron with water in it without purging all steam/water tank dray. Do this several times running dry with the burst of steam over towels to blow as much of the stuff out as possible. A new sole plate will cost close to $90 or so if you want to replace rather than clean it.
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 06, 2010
Water boiling inside but no steam wants to come out
Ronel:
The steam port is clogged up with lime. get some vinegar or CLR (calcium lime and rust remover from home depot or lowes or any store like that. Pour the water out of the iron and put the CLR or vinegar in the iron and let it sit for a while. Plug the iron into the wall and let it get hot. It should steam in a while... be careful that you do not breathe in the fumes.
Jun 20, 2015 | Irons
Lost steam pressure
see this causes and fix it.God bless you
Inspect the steam vents from the outside, and use a pipe cleaner or other small utensil to remove any excess buildup that is blocking the vents. Be careful not to let the buildup fall down into the steam vents.
  • 3 Clean the steam iron's directional spray tip. Minerals and other debris can build up on the nozzle over time and will greatly hinder the use of your steam iron.
  • 4 Pour equal parts vinegar and water into the steam iron's water supply tank. Put the steam iron above an empty pot, and turn the iron on. Let it steam the solution until all the water/vinegar solution is gone
    Sep 23, 2012 | Tefal UltraGlide Easycord FV4256 Iron
    The iron heats up, but when the steam generator button is pressed no steam gets through at all.
    Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
    As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
    This always works well for me and I hope it does for you.
    If so, please come back to Fixya and rate my advice!
    Jul 20, 2011 | Russell Hobbs 13153 Iron
    I have a Bosch Steam Generator Sensixx B25L that has suddenly stopped producing steam. The iron gets hot so that bit is ok, help, I have a huge pile of ironing!
    Your steam generator my have mineral deposits that are clogging the steam openings. One of the easiest things to do is to pour out the water and add white vinegar. Let the vinegar sit for about 2 hours. Then turn on the iron and press the steam button until the deposits are loosened and flushed by the heat and steaming vinegar. Do this on a towel or other absorbent fabric so you don't stain your ironing board. You may need to unplug the iron, let it cool and then gently **** the steam vents with a wooden skewer or toothpick.
    I hope this helps you. If it does, please rate my suggestion!
    Jun 01, 2011 | Irons
    The iron has plenty of water in the reseviour but will not steam. I have press the steam button and steam comes out but it will not steam otherwise
    Your iron may be due for a cleaning. After awhile the ports inside the iron become clogged with mineral deposits.
    Try using a mix of 1/2 white vinegar and 1/2 water. place the mix in the reservoir and allow the iron to heat up for steam until the reservoir is empty. Then do a second round with plain distilled water. Clean the the iron plate of residue after it cools.
    If the vinegar mix does not work (and you can do the mix a few times) try using a product such as "Lime Away" or "CLR" to dissolve the deposits. Hope this helps.
    Jul 12, 2009 | Irons
    Spray Mister is clogged (likely due to hard water)-can this be cleaned/fixed?
    try to clean the reservoir,etc.use agent that can dissolve sediments.then after cleaning, make sure use filtered water ,ok.use a cloth with cotton cloth.
    May 29, 2009 | Sunbeam Steam Master 4055 Iron
    Conair steam cleaner sc20 - plugged in, pushed button, no steam
    If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
    Apr 15, 2008 | Conair Compact Garment Steamer Iron
    Rowenta DG-980 Iron Logo
    310 people viewed this question
    Top Rowenta Irons Experts
    Joseph Hoffmann
    Are you a Rowenta Iron Expert? Answer questions, earn points and help others
