Question about Polyvision RoomWizard Room Scheduling System RoomWizard
My polyvision roomwizard is not taking reservations though i had checked the ip connectivity and also had hardware test run in the roomwizard
UPnP not supported TCP high performance not supported traffic congestion not supported
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Enabling DMZ:
1. On the left side of the setup page, click on the WAN Setup under Advanced tab.
2. Check the Default DMZ Server and specify the IP address of your computer.
3. Click on the Apply button.
Sep 11, 2009 | NetGear DG834G Router
I have a netgear rangemax won824 v2 I can connect to it fine, but I cannot connect to a works server after vpn connection successful. can someone help
VPN Passthrough Configuration
1. Please assign an IP address to your computer using the IP Address Reservation.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
d. On the setup page, please click LAN IP Setup under Advanced tab.
e. Click Add under Address Reservation then you will be brought up to a new window.
f. On the Address Reservation window, please select the radio button of the computer you wish to add.
g. If the computer you want is not on the list; click the Refresh button to update the table.
h. If the computer is still not on the Address Reservation Table; please enter the IP Address, MAC Address, and Device Name of the computer you wish to add.
i. Please click on the Add button when finished.
2. On the Set Up page of the router, select on Port Forwarding/Port Triggering under Advanced tab.
3. Click Add Custom Service and type VPN on the Service Name box.
4. Set the Service Type to TCP/UDP and input the VPN port numbers under the Start and End Port field.
5. Type in the last digit of the IP address of your computer. Then, click the Apply button.
Example: The IP address of the computer trying to establish the VPN connection is 192.168.1.2.
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.2
VPN2 50 51 192.168.1.2
VPN3 500 500 192.168.1.2
VPN4 1723 1723 192.168.1.2
Jun 07, 2009 | NetGear RangeMax WPN824 Router
I need to change my NAT settings from moderate to open and dont' know how to do that.
A. Determining the IP Address and MAC Address of a Computer: Note: Please use the computer for which the Ports are to be opened: For Windows 2000/XP users: 1. Please click on Start and select Run. 2. Type in cmd and click on OK. 3. In the Command Prompt, please type ipconfig/all then press Enter or Return key. 4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router). 5. Please note down the IP address and Physical address. B. Reserving an IP Address: 1. Please open any web browser like Internet Explorer or Netscape Navigator. 2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key. 3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password". Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it. 4. When the setup page opens, click on LAN IP Setup under Advanced tab. 5. Click on Add under Address Reservation. 6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table. 7. If the computer you want is not on the list, please click on the Refresh button to update the table. 8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add. 9. Click the Add button when done. C. Enabling DMZ: 1. On the left side of the setup page, click on the WAN Setup under Advanced tab. 2. Check the Default DMZ Server and specify the IP address of your computer. 3. Click on the Apply button.
Jun 04, 2009 | NetGear WGR614 Wireless Router
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Open block sites
C. Enabling DMZ:
May 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Help with ds connecting please advise would help
C. Enabling DMZ:
Apr 23, 2009 | NetGear WGR614 Wireless Router
Parser error
the Bin folder was not on the installation cd given by a provider
allow also webdav on IIS
Mar 19, 2009 | Polyvision RoomWizard Room Scheduling...
Wireless router dlink dire-301
1) Check and test your firewall. Your firewall, especially if its a software firewall like ZoneAlarm, Black Ice, Norton Firewall or something else could be blocking the connection. Disable your firewall and test the connection. You may have to resolve the problem by even uninstalling and reinstalling the firewall.
2) Check your IP address - Renew your IP address
3) Reset your TCP/IP stack by downloading and running WinsockXPFix.exe a Visual Basic program designed to fix corrupted TCP/IP issues, host file problems and a variety of other connectivity issues.
Oct 28, 2008 | D-Link Wireless
I have 2 desktop computers. im connecting a router to run a wire to the second computer the modem. when the computers connect to the router though, neither will get online. theyre showing full connection,...
Probably, a problem with the IP addresses. A conflict between the two computers. Try to connect to the internet with only one computer turned on. Let the other one turned off. Find out the IP address with the command ipconfig. You may have to renew it (ipconfig /renew).
Then, go to the router config: See the manual of your router. You may have to reserve the 2 IP addresses in your router configuration.
May 24, 2008 | Computers & Internet
Xbox 360
reserve the ip address for the xbox in the router
and do port forwarding and open the xbox ports for the reserved ip
Feb 09, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
Top Polyvision Computers & Internet Experts
David Payne
David Payne
Are you a Polyvision Computer and Internet Expert? Answer questions, earn points and help others
