Question about Electrolux Central Vacuum
Little suction on most outlets
There is little suction on all outlets but one. The outlet that has the regular amount of suction is nearest the the main unit. It seems like there might be a blockage somewhere in the line. What steps can I take to solve this problem ?
    Sergeant:
  • 201 Answers
Hey there charlestondr, The problem may be in the setup of the tubes throughout your home, having too many hard corners and therefore loss of sunction. However the power of your machine may be too little for your home size. In terms of the line blockage, try running a dry garden hose, through each tube. A little wiggling can help get past corners. You can strap a piece of cloth on the end to help clear along the way. Beware not to push too far into the machine, and be absolutely sure the hose is dry. Also ensure all filters on the machine have been cleaned. Good Luck!
Posted on Mar 26, 2008
  • 3,037 Answers
You can start by going to the vacuum and seeing if anything is blocking there, otherwise you can buy a long cable that is meant to unclog pipes, something like a device used in cleaning certain instruments such as the tuba, it looks like a metal cable with a brush on both ends and just run that through the outlets and try to find the clog and push it out
  • Benjamin Patri
    Benjamin Patri Mar 26, 2008
    you could also try getting a high powered vacuum or air compressor and pushing out the blockage with that, possibly rent or borrow one
    let me know if you need any more help or anything else
    thank you and have a Great Day
  • Benjamin Patri
    If you are going to push anything through, make sure that the vacuum is off, in case the cable may reach it and wreck the unit if it should be on.
    Good luck
SOURCE:
Vacuum cleaner Motors plural shut off during operation.
Probably not. Both motors usually wont stop working at the same time. You have given us very little information. Model number? Brand?
May 10, 2015 | Vacuums
I installed the Hoover Wind Tunnel Central Vac in my new home. After connecting the wall outlets and successfully turning on the system from the hose control, I discovered there is lots of air flow t
I would recommend checking your wall outlets where the hose plugs in for any type of clog in the tubing. If the vacuum itself has great suction but when you go to the wall outlets that is probably something in the hose that is stuck. If cleared it will most likely have excellent suction throughout the entire system in the house.
Jul 21, 2012 | Vacuums
My central vaccum cleaner has no suction at all outlets even at the canister. The motor is still working and blowing air out the air release tube. What could be the problem
Check the filter in the tank. If this is dirty, the motor will still run, but there will be little to no suction. Rinse thoroughly under warm water, then allow to thoroughly air dry before replacing into vacuum.
I recommend having two filters in order to use one while the other is drying.
Jan 27, 2011 | Electrolux Central Vacuum
There's little or no suction on my central vac so I think maybe something is stuck in the piping. how can I troubleshoot and/or fix this?
First, check the hose, wands, and power nozzle. You can check the hose by dropping a coin in one end, then lifting the length of the hose until the coin drops at. If it doesn't, then there's an obstruction in the hose that needs cleared. Depending on where th blockage is, it can be difficult to remove. The best way is to connect the wrong end of the hose directly to the in port of the vacuum and turn on. This presents an opposing suction to the clog and should clear it.
To check the powerhead, drop a coin in the wand end and allow it to drop through. If it gets stuck, there's a clog, probably in or near the elbow. Use a blunt object to gently push it through. You can visually check the wands.
If the filter is dirty, it presents an obstruction to the airflow, and will result in a loss of suction. Rinse and dry thoroughly. I recommend keeping an extra filter on hand and alternate use.
Check all outlets by plugging hose into them and turning machine on. Check for differences in airflow. If there's less suction in one than the other/s, then there's a blockage in that section of pipe, probably at one of the elbow. The obvious place would be the elbow at the outlet. Visually check for clogs.
If all the outlets have a low airflow, my first guess would be the filter in the vacuum, but there could be a clog in the main piping.
Another cause could be leaks in the hose, most likely at the ends where the hose connects to the connector or handle. The hose generally needs replaced if this is the case.
The fan system may be bad, resulting in reduced suction. It will need to be replaced if this is the case.
Depending on the age of the vacuum, the motor could simply be wearing out.
The best diagnosis can be provided by a reputable vacuum repair shop. Take the entire vacuum in for trouble-shooting if none of the above helped.
Jan 03, 2011 | Broan-NuTone CV450 Central Bagged Central...
The unit comes on and the exhaust blows out however no suction at all. l placed a wet vac on the unit where the bag goes and all of the outlets pull some air. The unit is the cv350. Thanks.
there would be 2 things potentially wrong here...
1) the black rubber gasket is missing off the body where the pail goes onto the machine. If that is missing there will be no suction.
2) This is a little more complex but will also lead to the same problem. up above where the bag goes there, is a filter. It could be clogged, but if you are getting a lot of air blowing out of the unit, I think it is more the rubber gasket between the motor and the body. You can check for this by looking behind the little motor pre-filter there (if it is even there) and check the motor intake for the unit. It is probably blocked or partially blocked with the motor gasket. To fix this you will need some weather stripping or another motor gasket.
Good luck.
Mark
Nov 08, 2010 | Broan-NuTone CV350 Performance Bagged...
No suction once hose is plugged in. If I go to another recepticle it has plenty of suction until I plug the hose in. I just bought this house and the owner was unable to help with operating manuals due to...
If it's just the one outlet, then there's probably a clog in the pipe between that outlet and the main pipe. You may be able to clear it by plugging the hose into a working outlet, placing other end to non-working outlet, and turning vacuum on. This may provide enough suction to **** out the clog.
If not, you'll probably need to use a mini plumber's snake to try to remove it.
Sep 11, 2010 | Broan-NuTone CV353 Central Vacuum
My kenmore centtral vac runs but does not ****. HELP11
#1 i assume u checked the bag and filter if so equipped?
#2 verify the hose is not plugged
#3 verify hard plumbing not plugged by taking something metal (quarter) and crossing the 2 little metal nubs at inlet (don't worry it is low voltage u wll not get shocked) it should ****
#4 if hard line plugged you may need a second vacuum to reverse flow
are all outlets not creating suction f so detach vacuum from piping and verify that vacuum is not the problem
May 06, 2009 | Vacuums
Stopped working suddenly. wont come back on.
try another otlet.if you have it plugged into a gfi outlet the little circit beraker on the outlet might have trippid if so push in on the red buttom till you hear it ckick.thatd resetting the gfi outlet.those kind of outlets can be found in thr kitchen,bathroom and outside.
Apr 16, 2009 | Oreck XLS700A Upright Vacuum
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Vacuums Logo
69 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
