Question about Haier 65-Pint Dehumidifier
Tank empty After having the humidifier on and running for 8 hours, I went to empty the tank and no water was there. It was completely dry. filter is clean, no fuse was blown, nothing blocking it. What is the problem. I could not find it in the trouble shooting page in the manual. Where can I get it fixed and how much would it cost me.
  • Haier Master
  • 43,501 Answers
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 04, 2010
I was given a energy star dehumidifier, but no hand book on how to set it to work, can you explain to me on how to do that please. It runs but I never have water in it is it working? Thxs
I have had several humidifiers. The larger the water tanks the better. If your water is always empty, its working fine. Just keep filling it up. A really dry house will suck up the water amazingly fast until you get a little humidity going, then it will slow down. Will make a big difference. MUST keep water in it. RJ
Aug 22, 2017 | Dehumidifiers
Tank is empty the monitor says its full the humidifier is connected to a hose
If it has a float to detect water level, it may be stuck in the full position.
Jun 12, 2014 | Danby DDR6588EE Dehumidifier
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    Do I have a filter I need to change in my dehumidifier MHDW
    i assume you have a humidifier and not a DEhumidifier? putting water in a dehumidifier defeats the purpose. it should remove the water from the air. don't fill the tank on the bottom. empty it. as for the filter, just use a vacuum across the front fins to remove the dust.
    May 10, 2012 | Windchaser MDH-W Dehumidifier
    I have a sunbeam 1387 warm mist humidifier. I need to know how to clean scale from the filter. It looks like it can be taken apart. Can it?
    Actually, Carol, it shouldn't be necessary to take the unit apart. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and allow it to sit overnight. Then empty the solution and fill the tank with Bottled Distilled Water. Turn the unit ON and allow it to run for 1 hour. Then empty any remaining Distilled Water. Doing all the aforementioned, should have not only cleaned the filter, but also the unit itself. If you use Bottled Distilled Water in the future, rater than tap water, the filter and the plumbing of the unit will stay clean longer and will require less maintenance.
    Hope this helped you. Please let me know. Thanks.
    Jun 26, 2011 | Sunbeam Warm Mist Humidifier Dehumidifier
    I purchased a 45 pint/day dehumidifier model # DD45P last year and it worked great. We needed to empty it almost every day as it was located in our lower level at a lake home. We have just returned to our...
    There are many reasons why a dehumidifier willnot work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
    Dehumidifier is running but no water is in bucket
    heatman101
    Apr 11, 2011 | DeLonghi Dehumidifiers
    Just bought, brand new. where to put water in? unit will not turn on.
    If you bought a dehumidifier, you will not need to put water in it. A dehumidifier removes water. A humidifier add moisture to the air, and you need to add water to this. Was your dehumidifier running before and then it stopped? If so, it will have a tank on the bottom that will have water in it that needs to be emptied out. Let me know if this is your problem.
    Sep 27, 2010 | Aprilaire 1710 Dehumidifier
    Dehumidifer stopped collecting moisture, blows air w/ empty tank
    Possible cause it's out of gas.
    you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
    Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
    Servicing a dehumidifier
    Keep the filter clean and when not in use empty the water tank and store the dehumidifier in a dry environment
    Jan 11, 2008 | Maytag M7DH45B2A Dehumidifier
    Haier 65-Pint Dehumidifier Logo
    190 people viewed this question
    Top Haier Dehumidifiers Experts
    Steve
    Bill Long
    Jim Thurston
    Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
