Question about Dell E173FP 17" LCD Monitor
My monitor was working and then turned to a black screen.
Everything was working fine and then the screen went black. The power is on and all the cords are connected. The power button is blinking green. Please help.
    President:
  • 1,561 Answers
The picture board of your monitor is malfunctioning since you the power led button is on and all connection are well connected, it means the picture board of your monitor as developed fault.
The picture board of your monitor is bad and will need to be replaced.
The best thing for you to do is to take the monitor to local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other not to complicate issues.
Take care.
Posted on May 03, 2010
2 Suggested Answers
SOURCE: Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
Posted on Jan 07, 2008
Screen went black
Swap monitor connections to determine if one of the monitors is not working.
If one is not working you probably have an internal problem. If power led responds to the off-on button but no picture is seen, the inverter has likely blown a fuse. Replace the fuse and resolder the leads on all 6 inverter transformers or the fuse might blow again.
Monitor Mike
Mar 27, 2009 | ViewSonic VP201s 20.1" LCD Monitor
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
LG W22h2TQ monitor just turned black
easy way to find out go to bestbuy and purchase a video card and install it if everything works out its the video card if not then its the monitor that went bad if its still under warranty send it back and get a replacement,
Dec 15, 2008 | LG W2252TQ Monitor
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Flatron l1717s blank screen
Common cause of this is the VGA or DVI connectors not screwed on tight on either the back of the PC or the back of the monitor.
Also try removing power by unplugging for 30 seconds, sometimes that will reset things.
Feb 16, 2008 | LG L1717S-BN 17" LCD Monitor
Black Screen
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Feb 08, 2008 | Sony VAIO VGC-V617G PC Desktop
Gateway monitors not powering on
Do you get an Amber light on either monitor?
Jun 21, 2007 | Gateway FPD1950
Dell E173FP 17" LCD Monitor Logo
386 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
