Question about HP Business InkJet 2800 Printer
Asking to replace new printheads
On Friday, my printer said I needed to replace the Cyan, Magenta and Yellow printhead cartridges. I did that, and continued printing.
This morning, it is asking me to replace the printhead cartridges again, even though they are brand new.
  • superjohn_96 May 03, 2010
    Thanks for your quick response.
    This is an HP Business Inkjet 2800, and the ink and printhead cartridges are all the HP ones. I haven't used any compatible ones.
    Problem Solver:
  • 6 Answers
Is it laser or inkjet, and cartridges are original ones or compatible ones, some printers will not accept comptible cartridges.
Posted on May 03, 2010
Blue ink won't print
The cyan print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 20, 2013 | HP Officejet Pro 8500 Wireless All-In-One...
I have been given a canon pixma MP160 with no ink cartridges. what sort do I look for in the store.?
This printer uses 2 ink cartridges.
  • Ink Cartridge Configuration 1 black cartridge, 1 color cartridge (cyan, magenta, yellow)
You need to purchase the cartridges that suit this model printer.
If the printer does not print properly then the printhead may be faulty and needs to be replaced, BUT these are expensive. It may be better to put your money towards a new and better printer as a new printer is not much more expensive than the cost of a new printhead.
Jun 13, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Hi, the magenta ink won't work on my printer hp office jet pro k8600. I have replaced it with a new one and even though is shows that it's full on the ink levels it won't print it at all, I have tried all...
Materials needed: New empty syringe (big one) Gloves (to protect your hands fromink) Alcohol Paper tissue (to clean the excessink) Empty Plastic bottle (Here you putthe ink from the syringe) Important: Ensure that you have put new Magentaink cartridge to HP K8600. Ensure that the printhead arerecognized by the printer or no light alarms. Instruction: Press the Power button to turn onthe printer. Test print in microsoft excel with4 color black/yellow and cyan/magenta. If magenta only is missing means youhave clogged problem from the host. Wear your globes, prepare thematerials needed. Open the top cover. Press and hold the Resume buttonuntil the carriage moves to the left. CAUTION: Be careful not to proceed until the carriage is on the left sideof the printer. If the carriage does not move to the left automatically, turnthe printer off and back on and then try holding down the Resume button again.The printhead can be damaged if the carriage is not all the way to the left forinstallation. Lift the printhead latch. Lift the handle of a printhead anduse it to pull the printhead magenta/cyan out of its slot. Put printhead in thepaper tissue upward. Your printer are still ON becarefull not to touch the flex copper circuit. Get your syringe, use this to pullthe ink from the nozzle cap ( see link picture) After the done the syringe method,Insert the printhead magenta/cyan into its color-coded slot. Press down firmly on the printheaduntil it snaps into place. Pull the printhead latch all theway forward, and then press down until the latch engages. Close the cover. The printer should align theprintheads automatically in a few minutes, printing an alignment page. Print a test with magenta coloronly, If it does not print, try to change the Printhead. This is the only solution I foundin my HP k8600 printing problem.christan_11_1.jpg
Jan 14, 2011 | HP OfficeJet Pro K8600 Printer
My out of warranty l7680 will not print or photocopy in colour. Printhead status says Refilled supply Detected in printhead Black No/Yellow Yes Magenta Yes/Cyan Yes Detected in Printer Black No/Yellow Yes...
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
May 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
My office jet L7590 printer suddenly quit on me. It keeps playing a message that says the printhead has a problem
Did you let one of your inks run dry? If so, you need to replace the effected printhead. This model has two, one for black and yellow, and a second for cyan and magenta. If you let the yellow run dry but have tons of black, it still effects the black/yellow printhead. Same with the other, either color going dry makes its printhead go bad. Either printhead will set you back about $75. Easy to remove and replace once you get the new printhead.
Bottom line with this model of printer...DON'T let you inks run dry. A new ink cartridge is $20 vs. $75 for a new printhead.
FYI - This is the most common mistake/problem with this printer. The Inkheads are built to last at least 40,000 prints. That's several years for most of us, that is unless you let the inks run dry.
Feb 09, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
The printer keeps saying there is a problem with the printerhead with the black/yellow. what can i do to fix this problem. The black yellow cartridge still have some ink in it. do i need to just change the...
Unfortunately, it sounds like you need a new printhead C9381A. You can hope that it's clogged from lack of use and go into printer properties and attempt to clean it (it will use a lot of ink in the process). However, the the black/yellow printhead generally wears out faster than the C9382A cyan/magenta printhead. Replacement should cost around $70 for each.
Oct 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printing yellow for black
Hi Jan,
Can you confirm that you are using a CIS or non-HP cartridges with this printer?
It sounds a lot like the printhead has reached a clogging point where sediment has built up in the black portion and loosens enough to printer a few lines before it re-asserts itself again.
Based on my experience of this printer, if you're using a non-HP delivery system for ink then you should consider replacing the black ink with a dyebase alternative instead of pigment.. Replacing the Black/Yellow printhead and running a number of test prints to purge the pigment ink in the printhead should then result in a clean and more reliable printout in future.
One other vector for problems is the cleaning area and I've found that this can become soiled with excess ink causing cross contamination within the inks of one printhead. As yet I've not found a reliable solution to counter this sort of issue.
Hope this gives some clues and hopefully some ideas of a fix.
Martin
May 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
Changing the printhead
FYI: The L7590 doesn't have any tape on either the cartridge or the printhead.
Right couple of things here...
1. The printheads in the L7590 are either K/Y (black/yellow) or C/M (cyan/magenta)... There's no single black printhead unless of course this is not an L7590 we're discussing here.
2. The cartridges ARE individual with K, Y M C (Black, Yellow, Magenta and Cyan).
It's likely that the printer has one of the following faults.
  • Chip contacts and/or chips on the cartridges are soiled and/or damaged. Try checking for ink on chips and contacts in the cartridge bay
  • The little white oval pump in the bottom of the cartridge bay has become disconnect or broken. This is used by the printer to pump ink into the printhead but it also detects pressure variations and has a logic circuit which declares low pressure as "no ink".
If the problem is the latter then you need to get the printer serviced and/or repaired at a service center.
If it's the former you should be able to fix it yourself.
If you're using non OEM (ie: not by HP) cartridges I'd recommend getting a new OEM/HP one to test before you go for a service as some cartridges are just poorly filled and/or designed.
Hope that helps.
Feb 03, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP Business InkJet 2800 Printer Logo
477 people viewed this question
Seeker5211
Seeker5211
