Question about Casablanca Fan (3845T) Brushed Nickel Ceiling
Light kit I am intalling the light kit and there are 2 black wires with the one blue wire secured by a wire nut in the kit along with two white wires in another wire nut. From the fan motor is a bue wire and a white wire. The instructions say connect the white wire to the other white wire (i am assuming both white wires). do the blue and black stay connected to the blue from the motor? There is no mention of the black wires in the instructions.
    Guru:
  • 351 Answers
Hi .. usually the light kits come with only two wires that are not connected .. a white and a black. Look again in the install kit and make sure you have located all the wires .. the wire you want is connected to all the lamp sockets .
Posted on May 03, 2010
Ceiling fan and light kit installation 4 wires 3/1 (red, black, white) from electrical box to 3 wire (black, white. green) from fan. How do the wires connect?
I'm assuming from your question the 4th wire in your electrical box is a bare copper wire which is the ground. The green wire gets wire-nutted to that. The white wires get wire-nutted together. I'm guessing you have two switches installed in the wall for the fan because there is a black and red wire coming from your electrical box (one for the light and one for the fan) connect the two black wires together. The red wire is then connected to the blue wire in the fan which is the light.
Dec 22, 2016 | Dryers
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
I have 5 Hampton Bay ceiling fans originally installed in my 2001 home. 3 have light kits and work great. I am trying to install lights on the remaining 2 but get no power. The 2 wires (blue and white)...
The supply power to the fan from the house should be HOT 24 / 7. The two lines going to the fan normally have wire nuts for connecting the leads on the fan to the house power supply line and the house common line. You want to tie the blue line on the light into the same wire nut that goes to the Fan switch. White is COMMON. Just add the lights COMMON (White) line to the wire nut that has the other two white lines in it. The blue goes to the Power line from the house. Add it to the BLACK (HOT) lines wire nut that has the fans wire in it. Use your meter to be sure of what color is common and witch is hot. If you have any trouble, let me know in detail what all the colors are from the house, fan and light. I'll put it in order for you. thank you. Please vote. Roger
Apr 14, 2011 | Hampton Bay Heating & Cooling
How do I wire a light kit for my hampton bay farmington fan? I want the fan and light to work from the wall switch
The blue (or black) wire from the light kit is connected to the black wire inside the fan cover.
The white to the white. Make sure to secure power to the circuit before attempting work.
Hope this helps.
l
Feb 20, 2011 | Heating & Cooling
Only have two wires to connect to
What timer are you installing?
Intermatic battery-operated timer with red, blue, black and green
Green connects to bare ground
Red is capped off.
Blue connects to one wire
Black connects to other wire
Push on-off button: if light comes on, timer wiring is correct.
If light does not come on, then reverse blue and black wires.
Other in-wall timers except Aube have red, black, white and green
Green goes to bare ground
Red connects to one wire
Black connects to other wire.
White: in back of electrical box are white wires twisted together and covered with wire nut. Connect white white to these other white wires.
If box does not have white wires described above, then connect white wire to bare ground along with green wire.
Push on-off or override switch: if light comes on, timer wiring is correct.
If light does not come on, then reverse red and black wires.
Dec 13, 2010 | Intermatic Inc. ST01C Digital In-Wall...
When wiring up the light, blue wire for the light should connect to the black wire in electrical box, correct
connect white wire from light kit to white wire labeled "for light" then connect black wires from light kit filter to blue wire from fan. Use wire nuts to make the connections
Feb 06, 2010 | Hampton Bay 24002 Ceiling Fan
Replacing old fan with a new broan fan and light kit fan works but light does not come on.the fan has a white and black wire and the light has a blue and a white .i pu the white and the blue to the main...
White wires are neutrals and must be tied together to the power lead-in white wire. The black goes to the hot interrupted by the switch. The Blue wire is the hot for the fan but is interrupted by a separate switch. If you want to use one switch then the blue goes to the same black for the motor.
Jan 31, 2010 | Broan-NuTone 679FL Combination Light Fan...
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Casablanca Fan (3845T) Brushed Nickel Ceiling Logo
216 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
