Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I sheint the lamp, but now is like the lamp .is
I sheint the lamp, but now is like the lamp .is blow again
  • 336 Answers
Hi,so you put a brand new lamp in and still didn't work ? Did you take it out and looked burned? If it did blow up again or didn't light up at all it could be a problem with something else.The most common failure is the ballast which is the board that powers the lamp.When that board gets to weak or provides a higher voltage it could make the lamp blow.ALso make sure everything is properly closed,(door cover) and reset the lamp hrs.
Posted on May 03, 2010
Replaced lamp 5 mnths ago now grn lht flashes then red lght fashes
May have lost lamp again. Vacuum (do NOT blow) out the area around the lamp housing and the fan above it, before replacing it
Apr 06, 2014 | Sony Grand WEGA KF42WE610 42" Rear...
2003 nissan pathfinder blows tail lamp fuse
you got a wiring issue that keeps shorting out fuses find that and that should take care of everything else
Mar 08, 2012 | Nissan Pathfinder Cars & Trucks
Replaced lamp worried it will blow again
it is not difficulty to replace lamp, please don't be worry
Dec 20, 2011 | InFocus X2 Projector
Wiper fuse blows as soon as you insert one
first....be sure the fuse is the right ampage. second...if the ampage is correct, and it still blows, do the following. Disconnect the ground-side of your battery. Attached test lamp to ground-side of battery. Take probe end of test lamp and touch anypart of the motor body frame. If the test lamp (DOES NOT LIGHT UP), you have an electrical short. Recommend OBD (On-board Diagnostic) analysis test.
Apr 25, 2010 | 1998 Subaru Forester
Channel B protection light is on and it blows 1 of 4 fuses. channel A runs fine --- help !
You likely have some semiconductor part failures on the side that is blowing fuses.
Put a 100 watt lamp in place of the fuse that is blowing so that you can test parts. The lamp will limit the current to a safe value and allow you to weed out the bad parts.
EXPECT that the power amp transistors (probably BOTH sides are bad (shorted) and that the probllem may have fried driver transistors and associated resistors back a stage or two. DO NOT replace the lamp with a fuse until the amp BALANCES with the lamp in place... one bad part left in fries the whole lot again!
Jan 06, 2010 | Music
The previous owner installed an after market Alpine CD player, It is wired into the dome light circuit and has a dead short. The dome light fuse (#12) 15A blows intermediately after inserting a new one and...
This could be a component or a wiring fault. It is easier to check the components so:-
1)Remove lamp and insert new fuse.
If fuse goes again, disconnect stereo, replace lamp and fuse.
If fuse does not blow the dump stereo.
If fuse goes again, trace the wiring and
If it still blows, then the stereo is likely to be faulty
Dec 21, 2009 | 2000 Dodge Dakota Quad Cab
Lamp on my infocus 4805 keeps blowing. This is the 3rd one.
don't forget to clean your pj all 250 hours of utilisation!!
Mar 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Samsung DLP HL-R6167W 61"
try removing the lamp again ,inspect it for hair and blow some air into the lamp housing,if this is new to you after replacing the lamp,its possible its been created .
Jun 14, 2008 | Samsung DLP HL-P5663W 56" TV
Epson 7300
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Apr 17, 2008 | Office Equipment & Supplies
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
