Question about LG WM2277H Front Load Washer
Drum bearing gone on my lg wm-16115fd
How can i change the drum bearing
i get a very noisey spin and ive got rusty coloured residue coming from around the motor please help
LG WM2277H Front Load washer - when i turn on the washer i hear a very loud noise. what or how can it be fix?
Posted on May 27, 2010
  • 20 Answers
I would definitely not attempt this if you have no experience. Is is quite a lengthy process. Specialised tools are required. Discontinue using immediatly, as it will cause further damage to machine and property.
Posted on May 05, 2010
Why do I have plastic particles sticking to clothes in my washer?
Is the machine noisey on a spin? if so probably the drum bearings have gone or the spider {or shaft }broken
Jan 30, 2016 | LG WM2140CW Washer
GRINDING NOISE on our LG WM-2277HW Front Load Washer
Its central shaft bearing must be inspected and probably replaced.
May 21, 2008 | LG WM-2277HW Front Load Washer
Washer will fill up with water but will only spin
is it noisey on spin? sounds like control board to me. try this , open door and turn steel bowl by hand, left then right. if u can turn the bowl in both directions it is not the bearings. please reply 4 more help.the bowl should turn free in both directions.
Apr 14, 2010 | LG WM-1832C Front Load Washer
How do you change drum bearing on lg wm-1290fhb washing machine
It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
Apr 05, 2010 | LG WM-1290FHB Front Load Washer
Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Mar 07, 2010 | Washing Machines
Washing machine makes noise on spin machine type LG
THE SOUND YOUR HEARING IS THE REAR BEARING BETWEEN THE STATOR AND THE DRUM. IF YOU'LL PULL THE BACK PLATE OFF THE WASHER IT'S PROBABLY STARTING TO GET A LITTLE DRIP RIGHT ABOUT NOW TOO. BEARING COSTS AROUND $20.00 OR SO AND IS RELATIVELY EASY TO CHANGE. YHE EASIEST WAY TO MAKE SURE IT'S THE BEARING WITHOUT PULLING IT OUT AWAY FROM THE WALL IS OPEN THE FRONT DOOR AND SEE IF YOU CAN SHAKE THE DRUM UP AND DOWN AND SIDE TO SIDE.
Sep 25, 2009 | LG WM-2277HW Front Load Washer
Noisey washing machine
i had the same problem check the holes inside the drum for a bra wire stuck in one of them which was my problem we also thought the bearings had gone but they were not hope this helps
Oct 15, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Drum won't spin freely
Are you sure that there is nothing sticking through the holes in the drum like a nail etc or a screw from trouser pockets, it could be that the heating element has come loose and is scraping against the drum or that the bearings have gone.
Feb 04, 2008 | LG WM-2077C Front Load Washer
Suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Aug 14, 2007 | LG WM-1480FHD Front Load Washer
LG WM2277H Front Load Washer Logo
218 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
