Question about Janome Memory Craft 4900QC Mechanical Sewing Machine
I think I've bent something!
I let the loose threads get dragged down under the bed and it made some loud noises and gave the message 'stop for safety reasons'. I have cleared the threads, changed the needle and checked for debri but when I now try to sew the upper thread appears to hang up on the bobbin case and causes the same message. It make a dreadful noise and stops.
    Problem Solver:
  • 5 Answers
When you have the foot down ready for sewing,the needle thread , pull on it slowly and make sure there is resistance through the top tension, if there isnt any then the tread will ball up underneath
Posted on May 03, 2010
Error message "the safety device has been activated. Is the thread tangled? Is the needle bent?" Occurred after needle no 5 broke and fell out. The machine
If the safety has been activated, there is something wrong with the machine that could potentially be dangerous--to the machine or you. You should probably take it to a technician.
Mar 15, 2017 | Sewing Machines
Why would machine make loud noise like machine gun. Stitching is fine but am afraid to use because it sounds like it is hitting something in casing.
Probably best to have the machine serviced. Sometimes a bent needle will make a racket if it is hitting under the needleplate. At any rate, it is probably better to get it fixed than injuring yourself or breaking the machine.
Mar 20, 2016 | Brother PE700 Computerized Sewing Machine
Why is needle bar locked in down position?
Your Owner's Manual should have a Troubleshooting section. You should give your brand and model type to make searches easier.. here's the cause for one machine:
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus&faqid=faqh00000109_000
Oct 18, 2015 | Sewing Machines
Messages about safe device activated & press the needle position button
The noise is because the machine is trying to raise or lower a needle and can't move. Several things to check. Did the needle break and jam in the bottom thread? Is the needle bent or jam? Did the thread jam in the bobbin area? I had a 'knot' of thread build up on the bottom and it hooked itself into the metal clip on the bobbin so that the needle couldn't raise. If thread jams in the bottom carefully cut the threads until you can free the hoop and material. Then check to make sure all pieces of thread and fuzz has been removed in the bobbin case. If it happens again check to see if the bobbin case or the throat plate is scratched or bent. If you are stitching Free Standing Lace on this machine or a piece with over 20,000 stitches I recommend starting with a new full bobbin and a new needle. As you get toward the bottom of the bobbin, thread seems to have a high likelihood of tangling or looping.
Nov 27, 2013 | Brother PE770 Computerized Sewing Machine
The timing is out on my consew 226R-1, how do I fix it?
Safety clutch may be disengaged. Push and hold down the right hand button on bed of machine and turn handwheel away from you until it comes to a stop. Still holding the button down, force the handwheel away from you until you hear a loud click. Release button and now see if you can pick up needle thread.
Jan 08, 2013 | Consew 226R-1
Babylock Esante stopped. Just makes loud noise but won't move even manually.
You probably have a jam. Start digging under the bobbin area.
If you get it all cleaned up under there... and it still won't move. Time for service by a pro. Could be something horrid like a bent shaft.
Good luck
Nov 03, 2012 | Baby Lock Sewing Machines
The upper thread breaks immediately I start operating
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw
to remove the old needle, place the new needle in the clamp with the flat
side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then
tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads
or lint
Apr 17, 2012 | Sewing Machines
I've had this machine for over 10 yrs. The problem is that I cannot seem to get the tension adjusted correctly. I was sewing through a batch of triangles and all of the sudden the thread under the...
try these suggestions,see if they will help
try changing thread--top & bobbin,, some thread does not stay good as some other does
usually needle have a flat side goes to the back of the machine, make sure the needle is pushed up into the needle holder--is it the right needle for the fabric
and even if it's a new needle, I'd try another new one,,it's possible it could be bent or blunt or warped
check the thread take up lever to see if the top thread is still on it, when the thread comes off the take up lever it can jam up a sewing machine
check the needle plate to see if there are any burrs on it
also clean under the needle plate & bobbin area for loose threads or lint
Sep 05, 2011 | Bernina Virtuosa 150
My Bernina sport 801 is making a loud screeching noise heard under the presser foot/bobbin area
clean the bobbin area for loose threads or lint
if this doesn't make the noise stop then it may need to be serviced
Aug 03, 2011 | Sewing Machines
My elna 6005 keeps on stopping ande I get the message stop for safety purposes. I have just had my machine serviced and I really don't know what to do.
Something is not quite right. Double check everything...loose needle, plug ins, threading, bobbin area for loose threads, etc.
Keep in mind that you've jostled the machine moving it from the service to your home. It could be as simple as the bobbin race being out of alignment. If nothing you do works... take it back and give the the person who serviced it the "look." and make him/her fix it.
Mar 13, 2011 | Elna Heirloom Edition 6005
Janome Memory Craft 4900QC Mechanical Sewing Machine Logo
122 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
