Question about Dryers
F2 will not come on kenmore elite gas
F2 will not come on
    Sergeant:
  • 166 Answers
F2 is related to the pump or your pump filter has become clogged. Depending on how comfortable you feel with doing the repair yourself you can try cleaning out the filter area first and see if that solves your problem.
First and foremost remove power to the unit by unplugging.
On most models you will need to remove the lower cover on the front for access. Be ready with a shop vac, buckets, etc. to catch any water that is in the tub or in the lines. Once you remove the front cover you will see the access to the cleanout. SLOWLY unscrew the access sucking up or disposing of water as you go and eventually the water flow will stop. Once you remove check for socks, undergarments, and other small items (you should be able to shop vac out this as well to make sure). If you find clothing items it is pretty much guaranteed it should solve your problem as long as it has not caused pump damage. Re-assemble completely, and try again. Be sure to properly re-install the cleanout and all parts.
Posted on May 03, 2010
2 Suggested Answers
  • 3 Answers
SOURCE: f2 error code
F-02 error relates to a malfunctioning user interface board, most commonly a stuck button.
Here's a link to the technical sheet for it which includes some tests you can run to determine the problem:
https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10035270.pdf
Posted on Jan 05, 2010
Kenmore Elite front load washer (model: 110 42936200) won't spin. It makes a buzzing/humming sound when it should be spinning. Any suggestions?
F2 mean that you have a drainage problem and could be that the pump is clogged. I believe the pump can be accessed from the front of the washer. Also make sure electrical connections are secure. Make sure no hoses are clogged or kinked anywhere.
Jan 23, 2014 | Sears Kenmore Elite 4.5 cu. ft....
Why does my kenmore elite washer keeps beeping when it reach the last 2 minute?
If you have an error code (F2) in red letters, the answer has been posted.
The Tinker
Nov 30, 2013 | Kenmore Elite 45986 Front Load Washer
What is an F2 code mean? I have a Kenmore Elite Dryer Model 110.67062600
http://www.managemylife.com/mmh/questions/231650-my-dryer-is-displaying-f2-whats-wrong-1
Jul 24, 2011 | Kenmore 659 Electric Dryer
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
I have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Mar 18, 2009 | Washing Machines
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Did you ever get a response about your kenmore elite microwave touch screen?
The F2 error code on your microwave oven is a membrane failure.
It is recommended that you replace the membrane first & if you still have problems to replace the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 06, 2008 | Kenmore Elite 21086
Dryers Logo
Top Dryers Experts
