Question about RCA R52WM24 52" HDTV Projection Television
BLACK LINE AT TOP AND BOTTOM ,GREEN AND RED GLARE ON EVERYTHING
  • 308 Answers
Convergence issue. Get an estimate from a service tech. May not be worth fixing.
Posted on May 03, 2010
Ip3500 printing misaligned vertical band
my copier nashuatec 3722 .when start copier give me code E-4
Dec 07, 2013 | Canon PIXMA iP3500 Printer
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Jan 10, 2011 | Miller Bobcat 3 Phase Welder Generator...
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the parts and the CD with instructions.
Jul 16, 2010 | Sony KP-46WT500 46" Rear Projection...
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Apr 07, 2010 | Car Audio & Video
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Ds lite flashes on but fuses are ok
One or both your screens have blown.
Try removing the motherboard from the screens and attach the battery the green light should turn on and stay on.
Now attach the lower screen and turn on. If the screen is ok the screen and green light will flash and then turn off. (if the screen doesn't flash the bottom screen is you're problem and will have to be replaced)
If this happens the problem is then you're top screen which you will have to replace.
Jul 26, 2009 | Nintendo DS Lite Console
Which wires are hot and which is the ground wire on Maytag DE7600 drier (back panel top to bottom 3 connections)
If you have the newer style, you should have 4 wires on the CORD <--- not the terminal block itself. They'll be; Black, White, Red and Green. The green goes to the frame/cabinet and the white ALWAYS (ALWAYS) connects to the center terminal. The Black and the Red attach to either of the 2 remaining terminals... doesn't matter which one.
If you have a 3 wire cord, don't worry about a green wire. Just wire it "black, white, red" or "red, white, black"... just make sure you put the white in the middle. Think Oreo cookie.
And to be specific about your question... The Black and the Red are the "hot" wires... each one carries 120VAC.
SG
May 23, 2009 | LG DLE2512W Electric Dryer
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
3 prong dryer to 4 prong
green is ground, white is netural. red and black are L1 and L2
or in other words on the dryer there is a 3 screw holder red and black go on the outer ones white goes in the middle and green goes to the cabinet of the dryer
Oct 31, 2008 | Frigidaire FEQ332E Electric Dryer
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Nov 06, 2007 | Sony KP-51HW40 51" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
