Question about Kenmore Washing Machines
The water runs right through my washer, occasionally on rinse cylce. I have to spin it out again and reset it to get it to hold the water in. Whats the problem?
    President:
  • 949 Answers
The problem is siphoning. Check to make sure the drain hose is not too far into the drain. I put together some information on this and what to do. Follow this link and if you still have questions let me know.
http://www.fixya.com/support/r4621172-clothes_washer_stop_filling_water
Posted on May 03, 2010
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Rinse problem
Sounds like a timer issue. Try this, Yes it sometimes works. Spin the timer knob vigorously six to ten complete turns. It may be that the contacts are stuck together and this frequently frees them. Timers are expensive, so this is worth a try. Good luck.
Jul 01, 2009 | Kenmore 22642 Top Load Washer
Occasionally it will overfill
The water level switch is your problem.
Open the control panel and remove the plastic hose from the level switch and blow through it.
Soap and dirt clog the bottom end and prevents the switch from stopping. The water continues to flow because of this blockage.
After you reattach the plastic hose , set the washer to spin and turn it on to reset the switch.
Mar 15, 2009 | GE WBSR3140DW Top Load Washer
Machine does not agitate, will spin and rinse including.
Yes, transmission. this is under ten year manuf. warr.
Feb 01, 2009 | Maytag PAV2300 Top Load Washer
Goes through all cycles by will not drain or spin.
If the timer hangs at points in the wash cycle, and you can manually advance, then the timer continues to run or runs shortly before hanging again, then the timer is bad and needs to be replaced.
Jan 24, 2009 | Kenmore 24032\24036 Top Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
52 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
