Question about Zanussi FJS1225W Front Load Washer
What does error code e90 mean - Zanussi FJS1225W Front Load Washer
  • 269 Answers
Error code 90 means it could be a communication error between the main interface and the main P.C.B. (PROGRAMMER).E90 can cover a few faults it could mean that the main board is damaged.have you had any power failures recently.If you are confident to have a look at the fault make sure that the main power is off. Remove the top lid there are 2 screws at the rear of the underside of the lid then check all the connections on the main board and the display board if possible remove any plugs you can get to easily and replace because it may just be a bad connection.Try this and then power up the machine and just try it on spin if no error codes come up then try it again.If this is not successful it would be too costly to repair.
Posted on May 03, 2010
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
Nov 13, 2016 | Simpson Washing Machines
E70 and E90 error code on intex pure spa pump... what do these mean and how do I fix it?
If alarm code E90 is displayed on the control panel, it means no water is flowing through the system. Check with Intex for a repair manual ( On line and google..)
Feb 25, 2016 | Intex Pool & Spa
What does e90 mean?
  • E90 Error - YouTube www.youtube.com/watch?v=IhHvw2K7XO0
    • BY D CUTHRELL
    • 3 MIN
    • 24K VIEWS
    • ADDED 2012-11-16
    Video embedded · E90 Error Code on Frigidaire Washer cleared with Hair Dryer.
  • Frigidaire E90 Error ' eHow www.ehow.com > Home > Home Appliances > Washer & Dryers Frigidaire E90 Error. Frigidaire front-loading washing machines offer a control panel with keypads to set the desired wash cycle and any options, as well as monitor ...
  • Zanussi Washing Machine displays an error code E90.? howtomendit.com > ... > Household Appliances, Washing Machines How to fix anything. Free repair help - zanussi washing machine displays error code e90.
  • Dec 23, 2015 | Washing Machines
    E90 Error,How do I fix or clear the E90 error I am getting on my spa?
    What should I do if code E90 appears on - Intex ' Frequently ...
    www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action...
    Jan 19, 2015 - What should I do if code E90 appears on my air bubble spa control panel? ... If alarm code E90 is displayed on the control panel, it means no ...
    Oct 14, 2015 | Pool & Spa
    What does error code E90 mean? Model # GLTF2940FS2
    Hey friend, thank you for your post!
    From my understanding you are receiving an error code of "E90" on your Frigidaire washer. I am showing that as an invalid error code. It might be a miscommunication with your control panel and I would suggest performing a reset on your washer. In order to reset the washer you would need to disconnect the power from it for roughly ten minutes. If you continue to receive an error code of "E90" I would suggest contacting a professional technician for proper diagnosis and repair. Hope this is helpful. -Matt
    Feb 17, 2015 | Frigidaire Washing Machines
    Bmw e90 fault codes
    the error codes are BMW specific and yes an error code would show up as a cam position sensor fault.
    May 11, 2014 | 2008 BMW 320D E90
    Frigidaire Atf6700fs2. Machine is giving me message E90. Can someone tell me plz what this means? Ty
    The E90 error code is not a common error but it may occur when the washing machine electronics get wet for some reason. This may happen if wet clothes are left in the washer for a prolonged period after the wash cycle ends or if the same load is washed repeatedly.
    Read more: http://www.ehow.com/info_12017619_frigidaire-e90-error.html#ixzz2kK4eIkIS
    Nov 09, 2013 | Washing Machines
    It is flashing E90
    The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem, may be a power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed.
    Good luck.
    Jun 02, 2011 | Frigidaire Affinity ATF7000E Front Load...
    E90 Error Code
    an E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
    Nov 08, 2006 | Zanussi FJS1225W Front Load Washer
    Zanussi FJS1225W Front Load Washer Logo
    532 people viewed this question
    Top Zanussi Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
